LC accelerator pedal.
Posted 11 May 2021 - 04:09 PM
Posted 11 May 2021 - 04:23 PM
Hi Paul, all the LC Toranas I have owned have had the pedal screwed to the floor and the carpet slotted to fit over them. Original carpets may have had stitched lacing around the slot but totally unsure about this. What does everyone else think? A very long time since I took one apart. I do remember that that the screws were always rusted and hard to get out due to corrosion even on cars only 15 years old.
Posted 11 May 2021 - 10:41 PM
Hi
Here is a pic of an LC XU-1 still fitted with its original carpet. The pedal appears to be under the carpet at the forward end of the heel pad.
Posted 11 May 2021 - 11:48 PM
Posted 12 May 2021 - 08:07 AM
I'm not so sure about this.
I seem to remember these things when they were new & the accelerator was held down by 2 screws which went thru the carpet. The whole accelerator was above the carpet.
I guess untouched original cars are now impossible to find.
Any brochure shots around maybe ?
Dr Terry
Posted 12 May 2021 - 08:57 AM
There is a rectangular cutout in the driver side rubber/plastic “protector” same size as the accelerator base.
I can check the carpet to see if it also has the same cutout.... or only screw holes.
I’m sure there are others with original cars, that may chime in soon....
Posted 12 May 2021 - 10:36 AM
Edited by S pack, 12 May 2021 - 10:37 AM.
Posted 12 May 2021 - 08:52 PM
#9 _oz772_
Posted 22 May 2021 - 10:06 PM
That photo is not of an original heal mat Bazza. I have a photo from the LC GTR brochure that shows how the pedal fits through a cut out in the heal mat. I just can't post it. I also have the dimensions of where the two screws are in the floor.
Edited by oz772, 22 May 2021 - 10:07 PM.
Posted 22 May 2021 - 10:15 PM
#11 _oz772_
Posted 22 May 2021 - 10:21 PM
So is it under the mat or on top oz?
The heal mat has a large hole cut out of it and the pedal passes through that hole and is screwed into the floor pan. However, the carpet is not cut; only the heal mat.
I can email pictures, but I don't think I can even PM them unfortunately.
Edited by oz772, 22 May 2021 - 10:24 PM.
Posted 22 May 2021 - 10:30 PM
#13 _oz772_
Posted 22 May 2021 - 10:41 PM
Pm sent
Pm sent
Posted 23 May 2021 - 07:38 AM
I believe one method is to use a photo hosting service and paste the photo link into the PM.
Posted 23 May 2021 - 12:13 PM
#16 _oz772_
Posted 23 May 2021 - 11:11 PM
Yeah, I can't be bothered...sick of junk mail. And it's not something I do often.
Posted 12 June 2021 - 05:02 PM
Posted 12 June 2021 - 05:29 PM
Right or wrong, I think I'll do it your way Paul.
The pic with heel mat cut looks like a factory cut in vinyl but looks bloody ugly.
Marty
#19 _oz772_
Posted 12 June 2021 - 06:22 PM
So I've done a bit more research on the pedal ,I've seen a few screwed down on top of the mat ,but I've also seen the pedal screwed directly to the floor and the pedal passed through the mat ,which I've done .The heal mat sits flush to the pedal once the underlay is cut away .The differences may be an Adelaide Brisbane thing.In any case I think under the carpet looks neater.Thanks fellas.
Nice result.
Posted 12 June 2021 - 07:23 PM
#21
Posted 12 June 2021 - 07:45 PM
#22
Posted 12 June 2021 - 10:39 PM
#23
Posted 13 June 2021 - 01:50 AM
#25
Posted 13 June 2021 - 08:38 AM
EJ through to and including HG holden all have balls.
