SF340 with Magnum Rims
33 replies to this topic
#1 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
  • Car:SLR5000 LH Torana
Posted 17 May 2021 - 07:25 AM
Hi any suggestions to what I should replace these with on my SLR5000 LH
Howie
#2 hanra
  • 10,831 posts
Posted 17 May 2021 - 07:45 AM
Standard 13in rims and hubcaps.
#3 Ice
  • 15,118 posts
Posted 17 May 2021 - 08:33 AM
Hell no
#4 Heath
  • 18,307 posts
Posted 17 May 2021 - 11:20 AM
Wheels that you like the look of.
If it's unflared, 7" front and 8" rear, 0 offset all around, should serve you well enough.
#5 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 17 May 2021 - 03:34 PM
Thats a tough decision kinda takes the meat out of muscle car. I took a pic of the spare, can you confirm its original and keeping in mind the odometer has only 67000so k's is it possible the tyre is also original fit. I will have to start new topic to upload pic.
Howie
#6 yel327
  • 13,074 posts
Posted 17 May 2021 - 07:41 PM
These. 15” far better tyre choices.
https://www.gumtree....opytopasteboard
#7 hanra
  • 10,831 posts
Posted 17 May 2021 - 08:52 PM
Howie
Is the Resto going to be concourse original?!
#8 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 18 May 2021 - 08:11 AM
I would like to keep it as original as it is now, eg: Have put Radiator in for new atrad core and to have outer bands restored. Only compromise I did was change from a 2 core to 3 core.
Howie
#9 claysummers
claysummers
  • 3,315 posts
  • Name:Clay
Posted 18 May 2021 - 01:22 PM
The magnums would look nice on my fb ute Howdy
#10 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 09 June 2021 - 04:08 PM
Hello to everyone. I can't find P/225/60 R13 92H tyres to fit my Magnum 13x7 jellybean rims, I did find these, would appreciate any thoughts or suggestions, I am not looking to flare guards etc
https://www.ebay.com...jIAAOSwsxNe83VT
#11 Shiney005
  • 9,029 posts
  • Car:Toyota Mirai
Posted 09 June 2021 - 09:22 PM
These will fit ok on the 7 inch rims. i reckon the 205's will look too skinny.
Attached File  tyre.PNG   537.3K   11 downloads
#12 hanra
  • 10,831 posts
Posted 09 June 2021 - 09:48 PM
Agree. 205’s will be pizza cutters. I think I’ve got 195’s on a 5.5in rim.
#13 claysummers
claysummers
  • 3,315 posts
  • Name:Clay
Posted 10 June 2021 - 05:03 AM
205 60 13 look ok but would only use them where space dictates. But yeh it's a battle trying to find any thing in 13" thst isn't made to suit pahs 6x4 box trailer or Nissan micra daewoogetz etc.
early Holden nut
#14 RallyRed
  • 7,836 posts
Posted 10 June 2021 - 10:02 AM
Nankang are doing a 205/60/13 in their AT-1 tyres.
Surprisingly, on the track they seem at least equal to a Yoky Advan. ( which are beez knees)
They are a little soft, but for occassional weekend drives, car club runs etc you may get some useful life from them.
They are priced around $200 and although a 90% track tyre, they are road  OK ( I understand).
#15 CI 0308
CI 0308
  • 736 posts
  • Car:77 LX SS, VX SS
Posted 10 June 2021 - 06:06 PM
I used to like the look of wider steel rims so you could get a decent tyre on them then with the hub cap back on.
I tried this on mine with just the hub cap sitting in the hotwire and I didnt mind it for something different.
Edited by CI 0308, 10 June 2021 - 06:09 PM.
#16 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 12 June 2021 - 12:49 PM
Thanks everyone for your input, much appreciated, still trying to decide.
Howie
#17 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 12 June 2021 - 12:53 PM
Will these stick out past the guard, bearing in mind I have the SLR500 LH no flared guards
#18 yel327
  • 13,074 posts
Posted 12 June 2021 - 01:36 PM
I’d still try and get some 14” rims. Plenty of HK-HG 14x6 mags around and 195/65/14 are easy to get. If you go to 14x7 it gets a bit tougher to buy tyres that work and look OK. I used to run 245/50/14 on my LX hatchback but they did rub on the beach of the front spoiler and you have to flatten the seam on the firewall. That was with 14x7 with 11/32” offset which is 4 11/32” backspace. However they are pretty wide tyres and are about 25mm taller than your 205/60/13 tyres. Even 25mm larger in diameter on the front wheels negatively affects your braking power so you don’t really want to go any bigger in diameter, and I don’t believe there is any readily available tyres in between 195/65/14 and 245/50/14. Probably your best bet is going to be something like a 225/50/15 which is only 5mm taller than 245/50/14. But finding 15x7 in Holden stud pattern in 4.25”-4.35” backspace is going to be hard. You can buy rims like these but they are 4.5” backspace on the 15x7, which should be fine. From memory they will get really close to the tie rods.
https://www.ebay.com...u4AAOSwtdpa5sXH
Edited by yel327, 12 June 2021 - 01:39 PM.
#19 yel327
  • 13,074 posts
Posted 12 June 2021 - 01:48 PM
back, not beach (of the front spoiler) in the text above^^^
#20 Statler
  • 6,282 posts
Posted 12 June 2021 - 04:50 PM
Bolt on a set of Simmons  :)
#21 Heath
  • 18,307 posts
Posted 13 June 2021 - 11:20 AM
With a 0 offset wheel they'll be probably at least a bit close for comfort on the front.
Most just run a 205 up front.
#22 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 13 June 2021 - 03:06 PM
What a minefield thinking 225/50 R15 tyres all round only 5.8mm higher with these rims 5x 108PCD
https://www.gumtree....rana/1271231787
#23 yel327
  • 13,074 posts
Posted 13 June 2021 - 03:54 PM
I’d stick with 7”.
#24 Balfizar
Balfizar
  • 461 posts
Posted 13 June 2021 - 06:53 PM
Maybe you could find something here:-
https://www.chrisnealewheels.com.au/
#25 LCK186
LCK186
  • 328 posts
  • Car:71 CK
Posted 13 June 2021 - 08:21 PM
hi all lh/lx toranas look great with 14x6 front and 14x7 rear hot wire mags on an un flaired car    no issues to get tyres       it might pay for you to look a photos of toranas with eg; hot wires or any other type of mag
