I used to run 265/50/14 rear and 245/50/14 front on an LX hatchback. The rear guards were actually cut not folded (spot welded back together) to clear the 265. The tyres used to also rub on the shock towers when cornering hard and I hit a bump. 235/60/14 fitted easily too.
On the front with the 245 on 14x7 had to roll the guards and flatten the seam on the firewall. Tyre used to scrub the spoiler back edge too. With the right offset 225 should be good.
This had HK-WB stubs with standard height front springs and 1” lower on the rear.
Edited by yel327, 16 June 2021 - 12:23 PM.
