Somethings not right.
21 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 18 May 2021 - 06:42 PM
Hi all , still can’t get to the bottom of why my shifter is hitting the side of the hole on the tunnel .
I don’t have any adjustment on the plate so I can’t move it over to compensate.The engine mounts seem fine installed as per the workshop manual and I even have the correct Opel mount on the crossmember and the correct crossmember. It seems it’s over to the driver too much and not central to the hole , nothing is bent .Any advise greatly appreciated. Cheers Paul.
Edited by Indy Orange, 18 May 2021 - 06:46 PM.
#2 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 18 May 2021 - 06:45 PM
Check that the rear crossmember is not on back to front.
Bazza
Edited by Bazza, 18 May 2021 - 06:46 PM.
#3 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 18 May 2021 - 06:50 PM
Hmmm no that’s seems ok Bazza.
#4 sibhs
sibhs
  • 2,702 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 18 May 2021 - 06:52 PM
Engine mounts on the wrong side???
#5 Bigfella237
  • 4,369 posts
Posted 18 May 2021 - 07:03 PM
It's been a while but I thought the flare on that rear crossmember was supposed to go toward the front to provide extra clearance for the extension housing?
Which would mean it's on back to front as Bazza said?
#6 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 18 May 2021 - 07:06 PM
Scoop goes to the front.
Bazza
#7 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 18 May 2021 - 07:12 PM
Ooooooops! Thanks guys !😬
#8 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 18 May 2021 - 08:54 PM
Will that actually bring the shifter back cenrtral to the hole?
#9 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 18 May 2021 - 10:16 PM
Hi - I had the same trouble. Looked at some photos etc and found mine was back to front. Swapped it round and no more clash with the edge of the hole. I would have to take a look to be certain, but it did move the lever across by maybe an inch.
Bazza
Edited by Bazza, 18 May 2021 - 10:16 PM.
#10 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 18 May 2021 - 11:29 PM
Thanks Bazza I'll get the crossmember right ,cheers mate!
#11 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 19 May 2021 - 04:23 AM
That cut out in your carpet is very neat. Is that the way it was supplied? What brand if carpet is it?
#12 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 19 May 2021 - 08:45 AM
Hi James, it’s classic loop carpet by Knox and I used a scalpel to cut around the hole . Paul.
#13 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 19 May 2021 - 12:13 PM
Thanks Paul.
#14 Balfizar
Balfizar
  • 461 posts
Posted 19 May 2021 - 03:25 PM
Mark the centre of the cross member (between the chassis rail mounts) then you will see any off set in the gearbox mounting holes and whether reversing the cross member will centreline the gearbox mounts.
#15 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 19 May 2021 - 06:29 PM
I'll get the crossmember the correct way first ,hopefully as Bazza says it will bring the shifter over slightly .I'll keep you posted.
#16 hanra
  • 10,831 posts
Posted 19 May 2021 - 06:34 PM
I hummed and arred over the direction of that crossmember… having the lip facing the rear seems to assist in draining the factory oil leak from the rear yoke seal.
#17 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 19 May 2021 - 06:45 PM
Yes and you'd have thought they would have made something similar for the factory diff leak and master cylinder .
#18 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 19 May 2021 - 11:37 PM
LOL
#19 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 20 May 2021 - 12:09 AM
Thanks ,all sorted ,so I corrected the crossmember which adjusted the shifter over about an inch as Bazza mentioned ,the crossmember has enlongated holes which allows for some sideways movement .
#20 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 807 posts
  • Name:JASO
Posted 20 May 2021 - 06:58 AM
What was used to edge the hole?? Looks very professional
#21 Indy Orange
Indy Orange
  • 2,846 posts
  • Name:Paul
Posted 20 May 2021 - 09:12 AM
Hi Jaso, I didn’t edge it ,I just cut around the inside diameter with a blade and it fit nicely around the outside diameter with a push.
#22 S pack
  • 15,538 posts
Posted 20 May 2021 - 09:51 AM
The thing that looks like edging around the hole n the carpet is the metal adapter plate that houses the shifter rubber boot.
