Disc Brake Front and Rear
33 replies to this topic
#26 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 807 posts
  • Name:JASO
Posted 29 May 2021 - 11:13 AM
Overshoes shoes were quite common in the day.
The drum needs to be at least 0.625" (1/16") oversize for No.1 oversize shoes to fit. The shoes also need to be radiused to suit the drum properly.
Being rear drums I'd have no issue with them being up to 0.080" oversize.
Dr Terry
How far can an oversize brake drum be, before it is deemed U/S .... wait till it cracks?
#27 Dr Terry
Dr Terry
  • 3,276 posts
Posted 29 May 2021 - 11:50 AM
I wouldn't take small 9-inch Torana drums much past 0.080".
With the larger (11-inch) drums on some US cars, they sometimes can go over 0.125" which is No. 2 oversize.
Dr Terry
#28 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
  • Car:SLR5000 LH Torana
Posted 12 June 2021 - 10:59 AM
Just had my rotors skimmed and told that was the last time, so wandering while its all stripped down should I use these:
https://www.ebay.com...a0AAOSwt5ZgUoLv
#29 dattoman
  • 16,470 posts
Posted 12 June 2021 - 04:04 PM
Or do them next time.... which will probably be 10 yrs.
Wonder what no name non Chinese products they are
#30 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 22 June 2021 - 10:30 AM
Hi all, just starting to repair rear brakes on SLR5000 LH bought new cylinders and spring kit. Just wandering can you buy new pistons for the brake cylinder, old ones a little pitted.
Howie
#31 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 22 June 2021 - 10:37 AM
Just had a look at the manual its not called a piston its a called Link Wheel Cylinder Connecting.
Howie
#32 dattoman
  • 16,470 posts
Posted 22 June 2021 - 08:35 PM
You mean pushrods ?
Just use the originals... some pitting is nothing
#33 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 23 June 2021 - 03:44 PM
Thanks Dattoman, had no luck trying to find new ones so I have just wired brushed them and painted one end black
Howie
#34 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 30 June 2021 - 05:24 PM
Hi all has anyone got any pics of front disc brake callipers removed, showing the backing plate? I forgot to take pics prior to disassembly
Howie
