Hi all i am putting a vr v6 in a uc torana i have the v6 conversion loom i need to know what wires go to the v6 conversion loom from the torana plug on the steering column i know they go to pink and violet on the v6 loom. Thanks Gary.
v6 to uc
Posted 01 June 2021 - 06:26 PM
Posted 02 June 2021 - 07:11 PM
https://v6conversions.net.au/lh-uc/
Toward bottom of their pages, says:-
If you have any further questions not covered in this information sheet please contact us for further information.
Edited by 73SUNBURSTEXYOUWON, 02 June 2021 - 07:13 PM.
Posted 03 June 2021 - 05:55 PM
hi i think i have fix the problem there is two wires that join together one is pink and one is yellow which goes to the coil pink wire says don't cut i have cut these to wires to about 8 inches what problems will i have if the wires are cut. Thanks gary.
Posted 03 June 2021 - 09:42 PM
I'm pretty sure it would be the yellow wire that says don't cut?
This is a resisted wire to the coil and if shortened it would reduce the amount of resistance.
You shouldn't need it at all on your conversion.
It is for points ignition.
Posted 04 June 2021 - 10:29 AM
The pink and yellow wires have to be joined together and they go to the pink wire on v6 conversion loom this is what pat from v6 said and the violet wire on the uc loom goes to violet on the v6 loom. What i understand is the wire that says dont cut is the pulse wire. Thanks Gary.
Posted 04 June 2021 - 11:08 AM
Lol.......no wonder it's confusing
Posted 04 June 2021 - 11:59 AM
Posted 04 June 2021 - 02:13 PM
Now i am confused if pink and yellow are joined together and connected to the v6 conversion loom why do they have to be bridged or bridged to which wires.
Posted 04 June 2021 - 02:30 PM
Edited by yel327, 04 June 2021 - 02:30 PM.
Posted 06 June 2021 - 02:02 PM
problem is fix thanks to all. Gary.
