Sheered Banjo Diff Stud
9 replies to this topic
#1 Nugget
Nugget
  • 36 posts
  • Name:John
  • Car:LX
Posted 16 June 2021 - 03:02 PM
My Genuine Repco RT4120 Torque Wrench just sheered of an upper stud of my diff housing as I was torquing the new Fiff in. 35ft/lbs.
Before I go to in with a hammer, the stud or the torque wrench, could someone please tell me are this press fit or screwed in?
I.e. can i simply tap the stud out with a big hammer?
Are replacements available or will I need to weld in a 3/8th UNC x 7/8 bolt?
#2 S pack
  • 15,538 posts
Posted 16 June 2021 - 06:42 PM
Good question. The studs do have a hex head and what looks like an aluminium washer under the head which leads me to think they might screw into the housing mounting flange.
One way to find out, pull the diff out and see if the broken one will screw out. Might be able to simply go to the bolt shop and pick up a new bolt.
Worst case they are pressed in and you'll need to rob one from an old housing.
#3 76lxhatch
  • 7,151 posts
Posted 16 June 2021 - 06:59 PM
^ I'm second-guessing it now, but before I read the above I would have told you they were splined like a wheel stud and a light press-fit (easy enough to tap out with a hammer)
#4 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 807 posts
  • Name:JASO
Posted 16 June 2021 - 08:04 PM
What age is the torque wrench? Has it recently been calibrated?
35ft/lbs is not alot of torque by any means, the stud may have been fatigued too, more than likely.
The industry i work in, we have regular calibration done to our Torque wrenches.
Not everyone will calibrate torque wrenches, but its something to consider when a failure to part occurs during assembly processes.
#5 hanra
  • 10,831 posts
Posted 16 June 2021 - 08:10 PM
Is this shot of mine any help?
Edited by hanra, 16 June 2021 - 08:11 PM.
#6 claysummers
claysummers
  • 3,318 posts
  • Name:Clay
Posted 16 June 2021 - 08:53 PM
They are splined. Tap out with a punch.
#7 Nugget
Nugget
  • 36 posts
  • Name:John
  • Car:LX
Posted 16 June 2021 - 10:38 PM
Thank-you. I've tapped it out. Came free OK. The Torque wrench is in new condition but for sure its 15 years old. The torque I set was right down the bottom of it's range which I can see can sometime be a problem. Desperately needs calibrating.
I am looking for a smaller one for this kind of thing. They seem pretty expensive.
I am going through old buckets of bolts. I am sure I have to put a long bolt centre in a short bold housing a while back ...20 years back :(
I went looking around the local shops today. No luck with a replacement
If I can't find one in Au I can order from here as a last resort;
https://www.doctordi...d-stud-kit.html
Does anyone know of a local source?
#8 S pack
  • 15,538 posts
Posted 16 June 2021 - 11:22 PM
Try some local differential repair/conversion shops.
#9 claysummers
claysummers
  • 3,318 posts
  • Name:Clay
Posted 17 June 2021 - 07:14 AM
Got some at home I pulled out of an old housing but they’re 60 years old and I won’t be back there for weeks. Get an appropriate size tensile bolt an tack weld head inside housing, that works. If it is at the bottom may weep.
#10 warrenm
warrenm
  • 2,105 posts
  • Car:1972 LJ Torana
Posted 17 June 2021 - 07:26 AM
The bolts are UNF not UNC.
