Torana - Powered by Ford.
#26
Posted 09 August 2021 - 05:04 PM
#27
Posted 09 August 2021 - 10:24 PM
#28
Posted 10 August 2021 - 09:41 AM
Great!
With enough cam, compression, and on throttles, no reason it won't sound great.
Standard they're very lacklustre, but no worse than an 2JZ-GE or similar.
#29
Posted 10 August 2021 - 09:56 AM
The auto FGIII turbo ute I drove as a test drive when I looked at buying one to replace my Hilux went pretty well, I wouldn't have called it lackluster! Although I also drove the same thing in a NA 6 XR6 ute and agree with Heath on that front, it wasn't as responsive as I thought it might be, was pretty tame. Possibly they also turned down the tune on the manual ones to protect the clutch? They did that with the V6 manual Navaras and Hiluxes but that was also because of the extra work a clutch does in a 4x4 offroad.
Can't wait to see the end result, good out of the box thinking.
#30
Posted 16 August 2021 - 09:33 AM
lol they make a lot of grunt, I was talking about the sound. They sound... like any other standard pedestrian modern in-line six
So on the weekend I discovered there's a dark blue LH/LX sedan with an N/A Barra on throttles, already completed and running. Had no idea anyone had actually done that before.
#31
Posted 16 August 2021 - 09:37 AM
Tight fit. I saw a Hemi 6 in one once and it was tight as well, but not as much as that.
#32
Posted 10 September 2021 - 06:07 AM
#33
Posted 11 September 2021 - 07:43 PM
#34
Posted 11 September 2021 - 09:51 PM
#35
Posted 12 September 2021 - 10:03 AM
#36
Posted 12 September 2021 - 07:49 PM
#37
Posted 12 September 2021 - 07:52 PM
#38
Posted 12 September 2021 - 10:24 PM
early Holden nut
#39
Posted 13 September 2021 - 02:18 PM
LOL!Oh, as in Ford 228.6mm diff?
1,100kg with a Barra would take some work, they are not a light motor and 1,100kg in a road going box Torana with a tough ~400hp drivetrain has probably never been done before.
I would expect my car is as close to that as anyone has ever strived for, but would be thrilled to be corrected. Have a read of my build thread to give you some ideas of weight reduction in a road going Torana.
They are ~1,200 to begin with, and you need to add the delta of a proper diff, a proper manual (TKX is 56kg plus bellhousing, clutch, and flywheel), you're saying some kind of bigger motor (and you want forced induction as well? That shit is heavy) that will have a bigger bore exhaust, hopefully bigger shocks, you will need front brakes...
You're talking >150kg of weight reduction efforts. That is a LOT. I mean what are you going to omit? Slim pickings in a Torana. The rear seat weighs nothing, there's no air con, no sound deadening, there's no stereo. Race doors on the rear would help if you don't care about rear passenger comfort and/or safety.
There's a bit in the bumpers, front seats, brackets and bonnet, they are obviously low hanging fruit. I've done all of that and hundreds of other things and I'm not down 150kg hahaha.
#40
Posted 13 September 2021 - 05:34 PM
