LH Torana Rear Brakes
9 replies to this topic
#1 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
  • Car:SLR5000 LH Torana
Posted 30 June 2021 - 08:39 AM
Hi just started to reassemble rear brakes, can anyone tell me what this part is and where it goes.
Howie
#2 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 30 June 2021 - 11:41 AM
Seems like this one has everyone stumped. I have looked at workshop manual with no luck. Thinking it might have something to do with the handbrake cable?
Howie
#3 rodomo
  • 17,999 posts
Posted 30 June 2021 - 12:09 PM
Marked here as a ferrule.
I'm pretty sure it goes between the shoe and the adjuster to stop them binding on each other..................but it's been a while  :D
#4 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 30 June 2021 - 12:37 PM
Thanks Rodomo I just found it myself on a ebay sale, but your drawing is much better. I was thinking it might stop the retaining spring from moving around, but then I couldn't figure why there was not 2 per wheel, your idea would explain why only 1. Iam assuming the ferrule protrudes through to the spring side of the adjuster
mechanism?
Howie
Edited by howie1300, 30 June 2021 - 12:37 PM.
#5 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 30 June 2021 - 12:39 PM
Also your pushrod looks different to  mine, is your picture earlier than the LH SLR?
Howie
#6 rodomo
  • 17,999 posts
Posted 30 June 2021 - 10:08 PM
Yeah sorry. The pic is front drums but same same. The washer part of the ferrule sits between the shoe and adjuster. The collar part locates it.
#7 claysummers
claysummers
  • 3,333 posts
  • Name:Clay
Posted 01 July 2021 - 12:33 AM
That's right. The ferrule keeps the adjuster concentric with the retaining rod hole in the shoe. Fit directly under the spring clip.
early Holden nut
#8 hanra
  • 10,832 posts
Posted 01 July 2021 - 12:28 PM
Where is that Brake image taken from?
#9 howie1300
howie1300
  • 102 posts
  • Name:Brian Howard
Posted 01 July 2021 - 02:03 PM
Thanks everyone much appreciated
Howie
#10 rodomo
  • 17,999 posts
Posted 01 July 2021 - 10:50 PM
An after market manual.
