Thanks for reply to SU carbs.
I have worked with SU carbs since about 1970, the E Type I have was my fathers, be bought it in 1970 and been in the family ever since. I also had a business in central QLD as Jaguar specialist, I have had a bit to do with SU carbs.
Caterham, I would have thought the 2 inch SU was to big for 202 but obviously you have them sorted. They are much better for tuning and balancing as well.
I just put air flow meter on each carby and my wife cranked engine [ not started ] and checked air flow. First carby was 3 kg/h, 2nd 3.5 kg/h and 3rd carb 3 kg/h. I lifted dash pot while cranking and there was no evidence of fuel in jet. I'm wondering if float level is to low. Will look into it.
Chris
Chris, the car as I received it had a set of 1.75 SU carbs on it. The previous owner had touted the car around to a variety of brain surgeons spending lots of money on "tuning". When I bought the car I consulted Ian Tate who had built the motor for this previous owner, and he told me what he had told him, that this particular combo needed bigger carbs. Ian just happened to have a set under the bench with a suitable manifold which he gave me to try. Frank Lowndes set up the tune/ needles etc after I had kitted the carbs to freshen them up, I still have them on the car 17 years later and never have to touch them tune wise. They work superbly on this motor which has one of Clive Cams " secret squirrel" cams in it plus Ians magic touch, which is a bit of a dog around town, but gets going rather nicely when you run it in a competition event etc. The car was in an earlier life a Group C race car and has been kept pretty much in that spec ever since.
