Hi All,
below is an "Idea" toward creating a 150List Register data base for the known existing.
It is quite extensive, pretty much covers it.
Also only Engine Specific with regard to any 92E modifaction ammendments, if applicable.
i.e. not inclusive of wiring or axle info.
So, in attempt to Knowledge Share. It would be nice to keep the thread "ON TOPIC".
Specific to your own, or a known - willing to share participant, toward including their **150List ONLY engine details.
Bare in mind too, Engines have had their fair share of mechanical surgery over the years, where original components would be removed,
replaced, modified or reproduced.
This Thread is not intended for undermining, hijacking or bombing of CAMS rules or anything other than that stated **above.
Template:
•150list Engine Number: JP Xxxxxx
•Owner Forum User:
•Single(S) Double(D) - Date Code:
•Sand Cast Pattern Number:
•Factory Fitted to Year/VAP:
•Current Fitted to Year/VAP:
•Original 92E Engine Internals, Fitted(F) Not Fitted(NF) Reproduced® Unknown(U):
1. Cylinder Bore Top Relief:
2. Pistons:
3. Conrods:
4. Lower Main Bearing:
5. Crank/Fly Dowels:
•92E Engine Externals, (F) (NF) ® (U):
1.Extractors:
2.Inlet Manifold:
3.Fan:
4.Balancer Retainer Plate:
5.Oil Pump Pressure Regulator:
6.Sump Scalloping/ Braised Baffle:
•Cylinder Head P/N - Date Pattern Code:
1.Inlet Valve Diameter:
2.Exhaust Valve Diameter:
3.Inlet Port Dimension HxW:
4.Exhaust Port Dimension HxW:
•Other Engine Internals if Not 92E
1.Bore Top Relief:
2.Pistons:
3.Conrods:
4.Crank:
5.Other:
•Camshaft (XH) (XJ) Unknown (U) Other(O):
•Images available to share Yes/No:
•Other Relevant Additional Info:
My Shared example:
•150list Engine Number: JP 392533
•Owner Forum User: 73SunburstExYouWon
•Single(S) Double(D) - Date Coded: S 9G3
•Sand Cast Pattern Number: 6
•Factory Fitted to Year/VAP: 24.8.73 Brisbane
•Currently Fitted to Year/VAP: 9.4.73 Adelaide
• Original 92E Engine Internals, Fitted(F) Not Fitted(NF) Reproduced® Unknown(U) To Be Advised (TBA):
1. CYLINDER Bore Top Relief: U
2. Pistons: U
3. Conrods: U
4. Lower Main Bearing: U
5. Crank/Fly Dowels: U
•92E Engine Externals, (F) (NF) ® (U) (TBA):
1.Extractors: R
2.Inlet Manifold: U TBA
3.Fan: R
4.Balancer Retainer Plate: R
5.Oil Pump Pressure Regulator: Modified Adjustable
6.Sump Scalloping / Braised Baffle: F
•Cylinder Head P/N - Date Pattern Code: 2815843 G90
1.Inlet Valve Diameter: TBA
2.Exhaust Valve Diameter: TBA
3.Inlet Port Dimension HxW: TBA
4.Exhaust Port Dimension HxW: TBA
•Other Engine Internals if Not 92E:
1.Bore Top Relief: Hand Ground
2.Pistons: +.030 flat top
3.Conrods: TBA
4.Crank: Blue
5.Other: Cylinders Sleeved
•Camshaft (XH) (XJ) Unknown (U) Other(O): O Wade391
•Images available to share Yes/No: Yes
•Other Relevant Additional Info: Extensive engine life repairs(raced), modified from original spec
GM P&A 150List Engine Register
73SUNBURSTEXYOUWON
, Jul 17 2021 10:45 PM
4 replies to this topic
Posted 17 July 2021 - 10:45 PM
Posted 18 July 2021 - 10:03 AM
Nice work, good idea
Posted 18 July 2021 - 05:16 PM
And I thought I had too much spare time.! Lol
Posted 19 July 2021 - 09:57 AM
LOL, no harm in havin a go .And I thought I had too much spare time.! Lol
If you have a subject Engine to share, by all means the register is open to it.
(Edit)Admittedly my engine is apart, so yes have time, to explore its makeup. To share what I know and the unknown.
Edited by 73SUNBURSTEXYOUWON, 19 July 2021 - 10:07 AM.
Posted 19 July 2021 - 07:58 PM
Best of luck
But don't expect too much
Secret squirrels are everywhere
