304 with 4L60E transmission LX Hatch
6 replies to this topic
#1 LOOKING4HATCH
LOOKING4HATCH
  • 68 posts
  • Name:Scott
  • Car:LX hatch
Posted 23 July 2021 - 03:41 PM
Hey guys
quick question, do I need to modify / cut the floor to fit this transmission in.
i put the engine and gearbox in on the weekend and the transmission seems to be hitting the floor, at the time I didn't have my new crossmember. (that arrived today)
#2 76lxhatch
  • 7,152 posts
Posted 24 July 2021 - 06:04 AM
I've got a TH700 with modified shifter and linkage, custom cross member, to fit with only tunnel changes being to accommodate the shifter itself. Its tight getting a reasonable driveline angle but it clears with HQ engine mounts:
http://www.gmh-toran...-7#entry1049661
(also see post 157 on same page)
A cable operated shifter would probably make life easier, but I don't see how you'd fit the factory linkage without cutting or modifying it, or having the trans too low/poor angle.
#3 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 24 July 2021 - 10:40 AM
the vy vz 4x4 have cable shifters
#4 yel327
  • 13,079 posts
Posted 24 July 2021 - 12:24 PM
Or a HX-HZ Statesman cable shifter which if mounted right will work with the original console.
#5 UCgazman
UCgazman
    UC's FTW!
  • 1,342 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 24 July 2021 - 06:24 PM
Wont select 1st gear on a 4spd trans though...
#6 yel327
  • 13,079 posts
Posted 24 July 2021 - 06:28 PM
The non-Statesman rod type will so can’t see why the cable one won’t. It may not show the gears but they do work.
#7 UCgazman
UCgazman
    UC's FTW!
  • 1,342 posts
  • Name:Garth
Posted 24 July 2021 - 10:30 PM
The shifter will drop into 1st but the trans will be in 2nd - same as the rod type
