Brake line flaring tool
Posted 30 July 2021 - 06:46 PM
Also I have to go from from a Commodore iso bubble one end to imperial 45 degree double flare on the other end is the possible?
Thanks in advance
Posted 30 July 2021 - 07:50 PM
I
Posted 30 July 2021 - 07:53 PM
I use a Brakequip tool very easy and quick to use, does single, double and ball flares. Not cheap but after using one of these your will never use the cheap Chinese ones again.
Posted 30 July 2021 - 07:58 PM
I have the cheap one...good for 5/8 fuck all...emergency only
I have the Mastercool hydraulic...if this is the one you mean
https://www.masterco...aring-tool-set/
Also handy for doing fuel fittings on GM's
Not bad...handy for some on car work...but cumbersome to handle
I also have a version of the vice mounted one above (Sykes Pickavant).. this is the one I prefer
Each has its uses on any given day
Posted 30 July 2021 - 08:28 PM
They do bell or ball what ever. Just be sure you have metric and imperial if you want to do commodore I suppose.
Posted 30 July 2021 - 08:42 PM
Also is it possible to do iso bubble on one end and 45 degree on other end of the same brake line?
Ps yes Mastercool hydraulic the one posted in the link.
Cheers Dave
Edited by 71xu1, 30 July 2021 - 08:45 PM.
Posted 30 July 2021 - 09:09 PM
I too suffered with the cheap shit clamp style for many years until i bought the eastwood professional jobby.
http://www.ppcco.com...eastwood28.html
OMFG i love this thing! Quick & perfect every time
Only drawback though is its vice mounted, could be used on the car but not easily.
I do like the look of the hydraulic units that Datto linked, maybe i should have some more research before buying mine but anyway was so impressed with the perfect job mine does that i wanted to replumb everything i could
Posted 30 July 2021 - 10:12 PM
Thanks for the replies all, Dattoman hmm, I do need to do GM fuel fittings. Also Dattoman chances of doing crap flares on Mastercool?
Cheers Dave
Just borrow mine when you want to do the fuel...if your WA metro
Patience gets good flares
Posted 31 July 2021 - 08:29 AM
Setup for HR disc
Posted 31 July 2021 - 09:27 AM
Reminds me
Must get my benders back from Christo
Posted 31 July 2021 - 11:45 AM
Yes you can do different flares each end
Setup for HR disc
Awesome thanks I'm doing VX master cylinder to HZ calipers in my FC.
Yep I'm metro WA, thanks for the offer.Just borrow mine when you want to do the fuel...if your WA metro
Posted 31 July 2021 - 12:44 PM
flaring tool apt-411a
Got this an love it, probably done about 200 flares with it.
bench or in hand is OK
you can get other dies for it.
eBay item number:253166544011
Posted 31 July 2021 - 07:06 PM
Ones involving brake lines or hydraulics - not an area to go cheap in my opinion
Posted 01 August 2021 - 10:38 AM
dave i have a flareing tool
Posted 29 August 2021 - 07:55 PM
Posted 29 August 2021 - 11:53 PM
EBay high octane tools flaring tool but the one on there is considerably dearer than I remember paying 2 or three years ago.
early Holden nut
Posted 30 August 2021 - 08:39 PM
