Poor rear quarter window fitment
15 replies to this topic
#1 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 13 August 2021 - 09:13 PM
Seeing if anyone has had this issue and how have you dealt with it.
When I have my doors shut on the gtr the rear window frames are proud at least 5 mil compared to the front window frame. The doors are aligned across the lower panels so that’s not the issue. Can the new rubbers push the quarter windows out that far? Do I need to bend the brackets that are riveted onto the quarter window frames to ‘pull’ the whole window closer to the body?
#2 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 13 August 2021 - 09:26 PM
Are the door rubber new?
Old door rubbers and new rear quarters could make that difference.
Marty
#3 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 13 August 2021 - 09:44 PM
All new rubbers Marty. It’s shitting me to tears when I look at it. Stupidly when the panel work was going on we test fitted everything bar the quarter windows as we assumed that if the doors line up the rest will follow. I’ll take a pic and post it up tomorrow in the daylight.
#4 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 14 August 2021 - 10:09 AM
"I was told" Haven't tested yet.
Rares quarter rubbers are too thick and best quarter rubbers are from Torana restorations.
I bought the Torana restoration ones for the LC but along way of fitting to give a first hand account.
Marty
#5 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 14 August 2021 - 12:45 PM
Attached File  40B3960C-A643-47DC-9DEA-728D53CB4593.jpeg   27.74K   18 downloadsAttached File  9D25A07D-3125-4C14-AAF3-0B04FBCAA536.jpeg   24.9K   5 downloads
#6 meanmachine72
meanmachine72
  • 2,005 posts
  • Name:Jono
Posted 14 August 2021 - 12:55 PM
my drivers side one sits like like that to
#7 S pack
  • 15,539 posts
Posted 14 August 2021 - 01:23 PM
Are they Rare Spares seals?
#8 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 14 August 2021 - 01:44 PM
Yes they are rare spares
#9 S pack
  • 15,539 posts
Posted 14 August 2021 - 04:03 PM
Are the windows difficult to close?
#10 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 14 August 2021 - 04:23 PM
Not al all. Close perfectly fine
#11 Zook
Zook
  • 1,536 posts
Posted 14 August 2021 - 06:14 PM
Window frames are bent or there's something wrong with the front mounts?
#12 S pack
  • 15,539 posts
Posted 14 August 2021 - 06:21 PM
Open the doors and take pics of the B pillars and front edges of the rear qtr window frames.
#13 evl666
evl666
  • 267 posts
  • Car:71 LC 73 LJ
Posted 14 August 2021 - 08:39 PM
The front door window frames fit neat against the b pillar and seals fit nice too. I’m going to pull the quarter window seal out and see if I can get the rear quarter frame to sit better. If I bent the front frames out to suit the quarters I would have a gap at the top for the rain to get in
#14 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 August 2021 - 07:07 PM
If it was me, I'd pull the rear window seals off & see if you can get the windows to sit properly. If you can, look into some new seals or doing something with yours. Otherwise if it's still bad, the frames are the problem.
#15 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 24 August 2021 - 05:21 AM
It may be worth keeping in mind the fact that these cars weren't built to perfection when new. Some cars had better gaps and panel alignment than others. Are we striving for a better finish than what the components are capable of. I'm not saying to be content with that fitment, it would annoy me too but these cars weren't built like a Rolls Royce.
#16 S pack
  • 15,539 posts
Posted 24 August 2021 - 07:45 AM
Rare Spares rear 1/4 window seal LC - UC Torana
Attached File  rrqs107.jpg   63.83K   3 downloads
Torana Restoration Parts rear 1/4 window seal LC - UC Torana
Attached File  RQS001-New.jpg   647.49K   6 downloads
The Torana Restoration parts seal looks closer to the original seal than the RSP product.
It also has the correct roebuck grain on the pinchweld.
