Starter motor solenoid
Posted 26 August 2021 - 08:29 PM
Posted 27 August 2021 - 05:00 PM
Edited by Indy Orange, 27 August 2021 - 05:02 PM.
Posted 27 August 2021 - 05:50 PM
Hope this helps
Posted 27 August 2021 - 06:06 PM
Should be everything on the starter solenoid positive, outside thread. Excepting purple wire which energizes solenoid from ignition switch when you turn the key. These are usually underneath the two threaded terminals. Other threaded terminal is earth or 0V as our resident EE puts it.
early Holden nut
Posted 27 August 2021 - 06:08 PM
Edited by Indy Orange, 27 August 2021 - 06:09 PM.
Posted 27 August 2021 - 06:52 PM
Posted 27 August 2021 - 06:59 PM
early Holden nut
Posted 27 August 2021 - 07:44 PM
There’s actually 3 terminals on my solenoid, still confused as to which one the push on purple one goes on.
The bottom 2 terminals are the same connection. Either one will do.
The top terminal is not used on Holdens but is on Fords & Valiants with points (non-electronic) ignition to short out the ballast on crank. Holden short out the ballast at the ignition switch.
Dr Terry
Posted 27 August 2021 - 07:46 PM
Put one end the big cable from the battery.
Very briefly splash the other end onto each of your 3 terminals, in turn.
Not the best solution, but you will soon see/ hear which one is the sol.
Note - make sure it's out of gear, handbrake on, safety glasses blah blah .
Posted 27 August 2021 - 07:59 PM
