AC fuel pump 6
Posted 28 August 2021 - 10:41 PM
Posted 28 August 2021 - 11:11 PM
They will leak oil out of the pivot too of worn
Posted 28 August 2021 - 11:35 PM
Posted 28 August 2021 - 11:50 PM
Posted 29 August 2021 - 09:33 AM
Easy to diagnose with the pump off. Just turn it upside down and fill the crank case with oil. It will flow out of the breather under gravity if this is the problem.
The seals are tricky to replace. In the end I gave up and fitted the bottom half of a good later metal top pump to my refurbished glass bowl top. By refurbished I mean cleaned and new valves fitted. They bolt straight up and pretty much indistinguishable.
Apart from the appearance, the later pump top had different port orientation, set up for flexible hose. Using it would have required modifying the pump to carb metal tube.
Sent from my iPad using Tapatalk
Posted 29 August 2021 - 10:23 AM
If it is leaking between pump face and block then you need to take the pivot pin out again and remove the arm and then reface the pump
face with wet and dry on a piece of glass or something nice and flat to get the bow out , it is common for them to warp slightly over time.
Not sure on this but the bolts that hold the pump in might not have a blind hole , and if not will need a smear of goo on threads to stop oil getting past.
Posted 29 August 2021 - 11:30 AM
Posted 30 August 2021 - 07:37 PM
Posted 30 August 2021 - 11:14 PM
