Has anyone got photos of the removal process of the rear quarters. I have started unpicking the bottom around sill etc. Wondering about the rolled gaurds....if you just gently straighten out then unpick or grind the edge and re weld. Ill grab some photos tomorrow. Thanks.
Sent from my SM-N960F using Tapatalk
Rear quarters 2 door
_Dmack350lj_
, Sep 01 2021 07:56 PM
4 replies to this topic
#1 _Dmack350lj_
Posted 01 September 2021 - 07:56 PM
Posted 01 September 2021 - 08:49 PM
Basically get a spot weld drill bit centre punch the centre of each spot weld. With the rolled edge personal choice, but either way you will need to unroll the guard to drill the spot welds, so I personally would unroll dress up lip then drill.
#3 _Dmack350lj_
Posted 02 September 2021 - 07:32 AM
Here are some photos. About to start unpicking up the B pillar then accross window etc
Posted 02 September 2021 - 08:34 PM
Beautiful, spot on. If you have trouble seeing spot welds a wipe over with a rag dampened in thinners makes it much easier.
Are you putting the same 1/4 back on? If so drill some of the spot welds all the way through so you can use them as reference points to line up the 1/4 panel when you put it back on.
Edited by 71xu1, 02 September 2021 - 08:36 PM.
#5 _Dmack350lj_
Posted 02 September 2021 - 09:27 PM
Thanks bud...good idea....ill do it incase i re- use it and the repairs work out.
