Hey Fellas,
I am upgrading from the old rusted Girlock cast iron front calipers on my 78 UC to PBR alloy calipers, When I bolt the PBR alloy calipers on loose, they slide back and forward fine but when I tighten the caliper bolts, the caliper seizes on the slides.
It seems like the bolt holes are not perfectly aligned or are drilled on a slight angle.
Has anyone here encountered this problem?
I stuffed about with it for hours and I'm out of ideas to solve it.
