I guess this is a LX Hatch build. Kind of
14 replies to this topic
#1 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 18 September 2021 - 05:03 PM
Hey guys, long time no see.
I occasionally pop to have a look to see what everyone is up to. Great to see old and new projects.
So I'm making an LX roof skin from scratch which needs to be "finish wheeled" front and back sections, canter rails need to be completed (Bent to correct angle and shrunk at front and back sections). The canter rails 90 degree bends I've left till the end as there needs to be (from memory) a 90 degree bend for the railing. So I cant do this bend or it will lock the canter rail in place.
Rear section needs shrinking to get get the correct curve, front section needs a recess for the front window to drop in.
Over all curve of the roof was ok till I bent down the rear section, the correct curve will come back when I shrink the rear section as mentioned previously.
Question is, how does the front section attach to the front pillars? I have an LX shell I normally copy off but I don't want to tear it apart.
Has anyone got pics of how it joins, cross section?
Thanks Guys. If moderators need to move this post to fabrication or something its all good.
Older pics, i thought they were more up to date. Ill post more later
Attached File  200953748_3744205269017269_7295872503690128986_n.jpg   111.6K   13 downloads
Attached File  223265554_925353638015787_5960069717056946655_n.jpg   124.4K   11 downloads
Attached File  218346148_1789082351275177_4850839201026089468_n.jpg   124.77K   12 downloads
Edited by Bart, 18 September 2021 - 05:05 PM.
#2 sibhs
sibhs
  • 2,702 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 18 September 2021 - 07:29 PM
Talk about a challenge. Good luck with that one Bart.
Looking amazing so far.
Marty
#3 Bigfella237
  • 4,371 posts
Posted 18 September 2021 - 07:48 PM
Wow! What he said ^ :spoton:
Once you've finished and you tally up all the hours you've spent, remember that some guy at GMH 45 years ago just used to hit a button and the press went "ka-choonk" and spat out a roof skin in about three seconds flat! :P
#4 claysummers
claysummers
  • 3,326 posts
  • Name:Clay
Posted 18 September 2021 - 08:10 PM
You forgot to factor in the tooling up process fella 8 )
#5 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 18 September 2021 - 10:44 PM
Thanks guys.
Any pics of how the front of the roof skin joins the front pillars would be great.
Yes a press and tooling would be great but big bucks. This roof skin is probably a weeks work but I've spread it over several months.
#6 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 18 September 2021 - 10:51 PM
Took a quick pic from the back
Attached File  241419951_438496080916415_1376373434799449151_n.jpg   105.56K   10 downloads
#7 RIM-010
RIM-010
    DON'T PANIC
  • 8,075 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 19 September 2021 - 07:32 AM
Unreal!
#8 76lxhatch
  • 7,152 posts
Posted 19 September 2021 - 07:51 AM
The lead has been removed here although the weld is still obscuring the edges a bit. You can see there's a small recessed flange that allows room for welding and filling.
#9 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 19 September 2021 - 11:47 AM
Thanks mate. That's a good pic, looks like the roof skin over laps the pillar, and its the pillar that has the small recess for the roof skin to sit into?
Edited by Bart, 19 September 2021 - 11:50 AM.
#10 76lxhatch
  • 7,152 posts
Posted 19 September 2021 - 03:32 PM
Yeah something like that, the roof panel is definitely on top
#11 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 19 September 2021 - 07:02 PM
Looking awesome. Well done. Is this for your car or just to see if you can do it?
#12 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 19 September 2021 - 10:00 PM
Thanks mate.
Its for a customer in Queensland. I've made similar low crown panels before but this is the first LX Hatch roof.
#13 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 19 September 2021 - 10:04 PM
Attached File  242193764_4412304172159052_4286770599483105283_n.jpg   46.58K   6 downloadsAttached File  241390247_865950583922855_5511913441299090275_n.jpg   44.62K   6 downloadsAttached File  242178755_464721081223721_6518013546475607564_n.jpg   71.83K   6 downloads
#14 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 19 September 2021 - 10:06 PM
How are you forming the edges?
#15 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 19 September 2021 - 10:11 PM
Previous project. This is the rear roof structure. Need to streamline the manufacture of this soon.
Attached File  59480731_10218853775354407_5596042679575117824_o1.jpg   65.92K   7 downloadsAttached File  main roof structure 58978348_10218853774954397_8267126099868123136_o1.jpg   71.91K   8 downloads
Formed in English wheel. The shrunk to make the contour (Just on that edge)
Edited by Bart, 19 September 2021 - 10:10 PM.
