Quality standard sump
13 replies to this topic
#1 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 21 September 2021 - 08:29 PM
Any recommendations on a good quality standard replacement sump for a a 308. Original is pretty battered so bought an Aeroflow one for about $70 . I've painted it already but its pretty flimsy compared to the original and want to check out what else is available . I see plenty on ebay at various prices but is the $150 one going to be the same as the aeroflow? Its no where near as rigid as the original and there is a noticeable weight difference.
#2 RedTaxi
RedTaxi
  • 64 posts
  • Name:Glen
  • Car:LX hatch
Posted 22 September 2021 - 10:50 AM
I think you can get re-build kits for the original pumps? I've always stuck with the factory alloy pumps.
#3 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 22 September 2021 - 11:42 AM
Specsavers mate !
#4 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 22 September 2021 - 12:03 PM
The rares ones are really good. Just built an engine using one and it was very much like factory.
#5 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 22 September 2021 - 02:21 PM
Looks like Rares only sells a complete kit not the sump on its own .
Just weighed my original and it’s 3.3kg the aerofow is only 2.7kg explains why it’s a bit flimsy
#6 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 23 September 2021 - 12:05 PM
I just bought the sump on its own from Speeds in Mitchell ACT who are the Rares supplier here in Canberra. Think it was $180.
#7 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 23 September 2021 - 12:14 PM
Ok thanks might give rares a call as can only see whole kit on website
How long ago did you buy it? They say only comes as the whole kit now
Edited by tuxedoss, 23 September 2021 - 12:19 PM.
#8 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 24 September 2021 - 12:14 PM
3 months ago.
#9 rexy
rexy
  • 3,777 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 24 September 2021 - 12:28 PM
Maybe you have a repro of the secret squirrel lightweight lemans sump?
In all seriousness though the sump isn’t a structural component and as long as it seals up properly why would you get a different one?
#10 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 24 September 2021 - 06:10 PM
That’s the worry if it seals up or not . The original is dead flat and quite stiff along the side rails . The other one has a few mm gap with a straight edge along it and can be flexed by hand . I just hate repo stuff that is cheap shit and not as good as the original . If we could make something in 1970 surely we can do same or better 50 years later
#11 Heath
  • 18,403 posts
Posted 24 September 2021 - 08:00 PM
You should re-write that as:
"If we could make something in 1970 surely China can do the same or better 50 years later"
#12 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 24 September 2021 - 08:35 PM
Yeah Heath sad but true
#13 rexy
rexy
  • 3,777 posts
  • Name:Rexy
Posted 25 September 2021 - 11:27 AM
Another question is should you be using a sump with better oil control than the original?
Something with a windage tray, crank scraper, anti surge design and an extra litre capacity?
#14 Rockoz
Rockoz
  • 4,065 posts
  • Name:Rob
Posted 25 September 2021 - 01:56 PM
I used an Aeroflow tin sump on an LS1.
In the instructions it says to tighten it up in a sequence similar to doing up head bolts.
Circular pattern from the centre moving to the ends to make sure it seals.
I checked mine on my welding plate, which I had drilled to modify an alloy sump.
Did a soapy water test and it had no leaks, unlike my first attempts at TIG welding to modify the alloy sump.
Rob
