1974 LH slr 5000 part numbers
19 replies to this topic
#1 marcoslr
marcoslr
  • 29 posts
  • Name:John Da Silva
Posted 23 October 2021 - 06:18 PM
more than likely been asked already but I am trying to confirm part numbers for the following to suit above car
MANIFOLD
CARBY
AIR CLEANER
According to the parts catalogue I have come up with the following
Manifold 9929854
Carby 17050641
Air Cleaner 9931795
The reason I'm asking is that I've read some threads that have completely different parts numbers for the same car and parts
John
#2 RallyRed
  • 7,841 posts
Posted 24 October 2021 - 06:45 AM
Maybe the parts are different pre & post ADR for pollution equiptment?
The LH gurus will chime in I imagine.
Edited by RallyRed, 24 October 2021 - 06:45 AM.
#3 hanra
  • 10,832 posts
Posted 24 October 2021 - 10:39 AM
I’ve found more often than not the part number cast onto the item does not match the number in the parts book.
#4 hanra
  • 10,832 posts
Posted 24 October 2021 - 10:49 AM
Example. The LH pets book shows P/N: 9929854 for the inlet manifold. However mine has 2823087 cast into it…
#5 Dr Terry
Dr Terry
  • 3,276 posts
Posted 24 October 2021 - 10:50 AM
^^^^^^^^ Correct.
Also AFAIK there were no pollution gear changes throughout the LH model run, except for the addition of a carbon canister around Jan 75. All LHs had to comply with ADR27.
Dr Terry
#6 marcoslr
marcoslr
  • 29 posts
Posted 24 October 2021 - 03:07 PM
make it hard to find the correct parts if they don't often match with whats in the catalogue and cast into the part
#7 rexy
rexy
  • 3,588 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 24 October 2021 - 03:36 PM
Makes it easier.... more options to chose from.
#8 marcoslr
marcoslr
  • 29 posts
Posted 24 October 2021 - 05:18 PM
ok I'm looking for the parts described in the post to suit October 1974 LH slr 5000 the carby must be complete and if requires rebuild its not a problem so if any one has one or know of some please let me know
John
Edited by marcoslr, 24 October 2021 - 05:20 PM.
#9 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 28 October 2021 - 12:31 PM
Inlet manifold and carby is the same as 308 HQ I think. I have also heard that there is a difference in the Quadrajets between auto and manual? An extra vacuum line somewhere perhaps?
#10 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 28 October 2021 - 12:44 PM
This is from HKTG. The HQ and LH manifold wont have the threaded hole next to the thermostat housing.
Attached File  H KTG . LH manifold wont have threaded hole next to thermostat housing.jpg   459.58K   6 downloads
#11 hanra
  • 10,832 posts
Posted 28 October 2021 - 01:04 PM
Thats mine. Not perfect. But does the job. I had a marine propeller repair shop carry out repairs on this one to get it up to scratch.
Edited by hanra, 28 October 2021 - 01:05 PM.
#12 marcoslr
marcoslr
  • 29 posts
Posted 25 November 2021 - 06:51 PM
are there any differences between rochester carbys with auto or manual gearbox????
#13 hanra
  • 10,832 posts
Posted 25 November 2021 - 06:56 PM
Two different part numbers listed for each. I’d assume perhaps an extra Vac take off port for the auto one as a guess?
Edited by hanra, 25 November 2021 - 06:56 PM.
#14 marcoslr
marcoslr
  • 29 posts
Posted 25 November 2021 - 07:00 PM
so does any one know what the correct part number should be for a october 1974 L31 Slr ??? I've come across so many rochesters with different part numbers !!!!!
#15 hanra
  • 10,832 posts
Posted 25 November 2021 - 08:19 PM
#16 hanra
  • 10,832 posts
Posted 25 November 2021 - 08:24 PM
Mine is P/N: 7045281
#17 marcoslr
marcoslr
  • 29 posts
Posted 26 November 2021 - 04:21 AM
I have the parts catalogue and workshop manual but every time someone tells me they have one the part number doesn't match!!!!!
#18 claysummers
claysummers
  • 3,333 posts
  • Name:Clay
Posted 26 November 2021 - 05:16 AM
Those will be the part number of the complete assembly, which doesn’t appear on the carb anywhere. Individual components will have their number cast in, such as throttle body, air horn and main body.
#19 hanra
  • 10,832 posts
Posted 26 November 2021 - 06:01 AM
Google my part number.
#20 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 26 November 2021 - 09:42 AM
Holden part numbers in the book. Rochester (or Carter) part numbers on the components.
I did some research into the L34 manual choke Quaddie a couple of years ago, but I have never looked into the auto choke variety. This list should help ensure you get the right one. I will phone a friend as he might know which one you are looking for, but I assume it will be the same as Brads.
Attached File  Quadrajet part number. DATE 1.JPG   51.73K   2 downloads
Attached File  Quadrajet part numbers.JPG   69.53K   3 downloads
Edited by Shiney005, 26 November 2021 - 09:42 AM.
