L34 Replica Build
54 replies to this topic
#51 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 11 January 2022 - 01:20 PM
T56's (non-Magnum) and TR6060's are OEM gearboxes from certain Commodores for example.
It's not that they are "too much work" to fit. They take a bit more work, and have advantages and disadvantages, but I explained my preference above.
Weight is also a factor. They weigh an extra 35kg over a Muncie.
Edited by Lima31, 11 January 2022 - 01:20 PM.
#52 Heath
  • 18,309 posts
Posted 11 January 2022 - 02:27 PM
Wow.
A TKO 600 is 48kg which is well and truly heavy enough. The six speeds are 10-18kg more depending on the spec I believe.
Equivalent to having lightweight bumpers and brackets on both ends of your car.
#53 RIM-010
RIM-010
    DON'T PANIC
  • 8,075 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 11 January 2022 - 07:19 PM
^ if you're going to have extra weight anywhere, down low in the centre of the car is where you want it
If you've driven a car with a T56/TR6060 you'll know that there really is no need for 2 overdrive gears. As Heath said, 4 gears for getting up to speed and one for coasting is plenty.
#54 rexy
rexy
  • 3,587 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 12 January 2022 - 05:17 PM
I suggest you find a few people with one of the tremec boxes and ask them how the shift quality is. Not the smoothest out there. The Toyota boxes have much better shift quality and you can still get a new R154 which will be more than adequate for what you intend to do.
#55 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 13 January 2022 - 10:32 AM
With the TKX the shift issues have supposedly been resolved, but I would like to talk to someone who has fitted one.
