I seem to have a dicky proportional valve (safety valve?) in my car as the brake warning light comes on every month or so irrespective of the handbrake position. The light is brighter when the handbrake is activated and duller when you disengage it. I was told to re-set the safety switch attached to the top of this valve which sometimes extinguishes the brake light but sometimes not and this week is a 'not'.
The history of this car I believe might be relevant to the diagnosis as the car sat for near 20 years up till 3 years ago so I went through and reconditioned the master cylinder, put a kit through the front calipers and new wheel cylinders on the rear, bled the whole system, and replaced all the original rubber brake hoses. The original master cylinder reservoir was like a cesspit of dried and crusty brake fluid. It was an all aluminium one so I assume it wasn't original to this car, so I replaced it with a big nut cast iron one. I never did think to clean the proportional valve which must have consumed some of that crud (I assume).
I went to a brake shop today and all they said was that it was unusual that the safety switch was being activated and to look for a problem elsewhere? Apparently the internal component is just a springloaded rod with grooves that the switch pin drops into if there is a drop in brake fluid pressure from front or back brakes.
This has been an intermittent issue with this car for 3 years. Does anyone have any idea;s?
Edited by MFM, 24 January 2022 - 05:28 PM.
