Switches are long gone
You won't buy a new one
But while out you should be able to test it
Long ago when I worked for the brake shops - 15 yrs ago
We got our o-rings from bearing services and their part # was BS010
+1
Posted 27 January 2022 - 10:14 PM
+1
Posted 23 September 2023 - 09:34 PM
More LJ distribution block questions
,I am replacing brakes on my LJ and am wondering how to remove the shuttle/piston from the brake fail block to replace the o rings.
I have blocked one port and put air onto the other port, hoping the shuttle would be pushed out. It doesn't move but the air is blowing past the shuttle. It seems the shuttle is jammed.
Whats the best way to
Posted 23 September 2023 - 09:36 PM
What's the best way to get the shuttle out and renew the o-rings?
Cheers, Luke
Posted 23 September 2023 - 09:42 PM
IMG_0508 | brake distribution block | Smiling | Flickr This is the end where the compressed air just blows past the shuttle.
Next question is with the actual switch - is this switch extended or retracted? It is jammed also. IMG_0511 | brakefail switch | Smiling | Flickr
Thanks in advance, Luke
Posted 23 September 2023 - 11:54 PM
You need to physically yank the valve out of the centre of the unit
And free up the switch so it moves
Soak in metho for awhile
Posted 26 September 2023 - 03:31 PM
Hi Gents,
Problem solved!, I found the info in another thread, and pushed out the shuttle, with a 2mm punch through the front brake fitting.
Also i freed up the plunger on the switch and it now tests good. (switch open with plunger retracted and closed with the plunger extended.)
Cheers,
Luke
