IMG_28211.JPG 222.24K 10 downloadsAfter some advice please on LC/LJ Torana brakes (disc brake front end) brakes are really poor and due to fairly agressive cam which i believe creates poor vacuum (around 8hg inch on vacuum guage), tried a booster tank but didn't make any difference. I might have to invest in an electrical brake booster but are around $500. The question i have for forum member is if i need to re-install adjustment levers on rear brakes as per manual (stupid question i know) as i removed when springs broke some time ago as was told were only for self adjustment of brake shoes. I have adjusted rear brakes up as far as i can before brakes bind, but when pedal depressed can still turn by hand. Front brakes stop solid when brakes applied. Have re-bleed and checked pushrods work on slave cylinder which checked out ok. Any help would be greatly appreciated and apologies for asking such a stoopid question! Cheers in advance: Paul
IMG_28231.JPG 198.54K 8 downloads
