Edited by madtoranajzedded, 27 April 2022 - 01:01 PM.
Leyland p76 rotors to lj disc stubs
#26
Posted 27 April 2022 - 12:58 PM
#27
Posted 27 April 2022 - 01:43 PM
Aren't P76 rotors already 5x114.3? That is the best part of using them... you already get god's stud pattern.
Tim put P76 rotors and Wilwood 4-pots on his LJ. Just use everything he used.
http://www.gmh-toran...iary/?p=1066274
His kit certainly wasn't for drum brake stubs... just normal disc stubs. You could make an adaptor bracket for either but I don't see any real advantage of using the drum brake ones. The setup would be more work, and a less tidy, heavier result with the drum brake ones.
Edited by Heath, 27 April 2022 - 01:45 PM.
#28
Posted 27 April 2022 - 03:03 PM
Thats brillant mate .thankyou kindly for pointing me to Tims thread.that helps me tremendously.didnt,think of the centre bore size much either.the welds are 80.772.p76 hub 71.5 so will have to make some alloy ring spacers up for a snug fit.
Edited by madtoranajzedded, 27 April 2022 - 03:04 PM.
#29
Posted 27 April 2022 - 03:52 PM
Edited by madtoranajzedded, 27 April 2022 - 03:54 PM.
#30
Posted 28 April 2022 - 09:17 AM
I run these discs on 2”drop stubs and 2” lowered springs in one of my LJs. If you are running draglites you will need to be very careful with caliper choice.
The 15 inch draglites wont clear a Hoppers/UPC 287mm setup for example.. Biggest draglite i could get to fit under the front was 6 inches wide.
#31
Posted 29 April 2022 - 12:47 AM
Screenshot_20220429-003530.jpg 371.48K 3 downloads Screenshot_20220424-023452.jpg 325.17K 3 downloads
Edited by madtoranajzedded, 29 April 2022 - 12:51 AM.
#32
Posted 29 April 2022 - 07:08 PM
Mine are drilled for HQ.
Posted 29 April 2022 - 07:32 PM
#34
Posted 29 April 2022 - 07:38 PM
RDA68BD
#35
Posted 29 April 2022 - 07:57 PM
Edited by madtoranajzedded, 29 April 2022 - 07:58 PM.
#36
Posted 29 April 2022 - 08:03 PM
Undrilled rotors don't come with studs
#37
Posted 29 April 2022 - 08:41 PM
#38
Posted 06 June 2022 - 03:14 AM
Edited by madtoranajzedded, 06 June 2022 - 03:15 AM.
