Front end
front end valance panels
5 replies to this topic
#1 dacastle
dacastle
  • 82 posts
  • Car:LC gtr
Posted 05 May 2022 - 03:32 PM
Can anyone help with this
I have been advised the LC didnt have this holes in the front valance - I have had a new front end put on the car as part of the rebuild.
Can anyone confirm this is the case so I can get them welded up / patched up
#2 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 05 May 2022 - 03:41 PM
No only LJ I believe.
The cut outs are for the later type stone tray bracing.
Weld them up and if you want to run a stone tray, an earlier type without bracing will still fit.
#3 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 05 May 2022 - 10:17 PM
Also make sure your bumper steels go into slots not a square hole. They normally need welding up too.
Marty
#4 71xu1
71xu1
    Dave
  • 1,265 posts
  • Car:LC GTR XU1
Posted 05 May 2022 - 11:36 PM
Early LJs before the adr change were same as LCs no holes, no extra bracing on stone tray.
#5 dacastle
dacastle
  • 82 posts
  • Car:LC gtr
Posted 06 May 2022 - 07:43 AM
Marty
Thanks Marty
I am unsure what you mean about this - where should the slots be?
Thanks Adam - they will be welded up
#6 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 06 May 2022 - 08:16 AM
The later fronts have a square hole to allow for bigger bumper iron. LCs need to look like this.
