yellow chromate removal ?
4 replies to this topic
#1 UCSLE
UCSLE
  • 728 posts
  • Name:troy
  • Car:Goggomobil
Posted 12 May 2022 - 11:05 PM
How do you remove yellow chromate coating from carbys  ?
have tried heaps of stuff but doesn't want to come off
Want to remove it so i can polish the carby , not keen on sanding it off
#2 Bruiser
Bruiser
  • 871 posts
  • Name:Bruce
Posted 12 May 2022 - 11:16 PM
I soaked a bit of a scrap holley in clr for a while to find out, turned it nice and grey.
Cleaned up nice with fine steelwool, not sure about doing the nooks and crannys, though.
#3 IanC
IanC
  • 613 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 13 May 2022 - 06:01 AM
Not sure if this helps any. But just in case it does.. https://www.finishin...ry bright zinc.
#4 Bruiser
Bruiser
  • 871 posts
  • Name:Bruce
Posted 13 May 2022 - 10:46 AM
The stuffs in Ian's link above are better than mine. From memory, the clr leaves a
grey slightly powdery residue that feels dusty to the touch and definately needed
a scrub to polish it up.
Maybe best for showerheads only
#5 UCSLE
UCSLE
  • 728 posts
  • Name:troy
  • Car:Goggomobil
Posted 16 May 2022 - 03:45 PM
Tested out cleaning the top part of the carby
Could not find any of the stuff mentioned so i drowned it in carby cleaner then scrubbed it with wire brush
it got rid of most of the colour then polished it
Now to do the rest of it plus polish that part a bit better
Attached File  carbs.jpg   233.68K   4 downloads
