Broken 202 Cam
31 replies to this topic
#1 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 11 June 2022 - 02:27 PM
Alright gents, let me know how #@$^%& I am. I haven't torn down the motor yet but it appears my cam has snapped between the fuel pump and the dizzy/oil pump.
I have a 202 with a 161 head on it. Are these interference motors/heads.
#2 Rockoz
Rockoz
  • 3,964 posts
  • Name:Rob
Posted 11 June 2022 - 03:38 PM
Are you sure you havent just stripped the distributor gear?
Common problem.
Easy fix.
Rob
#3 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 11 June 2022 - 04:51 PM
Unfortunately it's not just the dizzy gear, I replaced it with another I had and it still doesn't spin. Pulled it out and looked down the dizzy hole and cam doesn't spin while turning over.
Thanks,
#4 S pack
  • 15,538 posts
Posted 11 June 2022 - 05:12 PM
Pull the rocker cover and see which valves are moving and which ones aren't. At the end of the day your only option is to remove the engine, put it on an engine stand, remove the sump and timing cover to remove the broken camshaft.
Edited by S pack, 11 June 2022 - 05:12 PM.
#5 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 11 June 2022 - 05:46 PM
Have you checked the timing gears? A friend of mine had these wear out recently.
#6 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 11 June 2022 - 07:15 PM
Yeah I plan to rip the engine out tomorrow morning. Fuel is still pumping via the mech pump so the timing gears must still be Okay. That's why I think there is a break in the cam between the dizzy and fuel pump.
Moreso just worried about valves being bashed, just had the head reco'd 😕
Edited by avoidev, 11 June 2022 - 07:16 PM.
#7 rodomo
  • 17,998 posts
Posted 11 June 2022 - 10:14 PM
Holdens are free spinners
#8 rodomo
  • 17,998 posts
Posted 11 June 2022 - 10:54 PM
Holden 149 to 202 6's are free spinners (have to be politically correct)
Edited by rodomo, 11 June 2022 - 10:56 PM.
#9 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 12 June 2022 - 11:27 AM
Update for anyone that's invest. Engine cam decided that it didn't want to exist and more and performed a half cam delete.
https://freeimage.host/i/h0R4pI
https://freeimage.host/i/h0RrkN
#10 LJ RB30
LJ RB30
  • 974 posts
  • Name:Trevor
Posted 12 June 2022 - 11:56 AM
Wholly crap mate! There's been some serious forces coming to a sudden stop happening there!  :cry:  :cry:  :cry:
#11 S pack
  • 15,538 posts
Posted 12 June 2022 - 12:17 PM
Far east, never seen that before. Were you spinning 7k rpm when it let go?
#12 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 12 June 2022 - 01:29 PM
That's the funny bit, this engine is super mild. 30tho over, cam was a 666 from crow and the head was a YT 161 with standard YT valves. So I'm completely starstruck as to why it's gone boom. Was just taking it round the block 50kmh.
Disclaimer this was my first time rebuilding an engine at all, so chances are I #@$^%& something up.
Edited by avoidev, 12 June 2022 - 01:30 PM.
#13 S pack
  • 15,538 posts
Posted 12 June 2022 - 01:55 PM
Looking at your pics I'm thinking a broken lifter may have been the catalyst to all that damage.
#14 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 12 June 2022 - 02:18 PM
Thanks S Pack, that's similar to what I'm thinking too. Could've been a lot more catastrophic so I'm pretty happy getting away with half a dozen damaged lifters and the cam and cam bearins being trashed. Nothing ventured nothing gained, right.
Old man reckons this is the perfect excuse to chuck in a 8. Might give it a thought.
#15 Ice
  • 15,122 posts
Posted 12 June 2022 - 10:23 PM
Your new user name
Snapper  :)
#16 jpxu1
jpxu1
  • 549 posts
Posted 12 June 2022 - 11:17 PM
Couple of things I note:
Looking for a cause for the cam damage, I'm wondering where the No.1 conrod is since it's not attached to the crank like I would have expected (and no real reason to have been undone on purpose at this stage)???
Not a baffled sump - If a rebuild is happening, I would be after one of them.
JPXU1
#17 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 12 June 2022 - 11:36 PM
JPXU1
And number 2 rod appears twisted out of shape, or is that an optical illusion?
#18 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 14 June 2022 - 06:46 AM
Keen eye, I didn't notice it looking out of wack, I'll double check this arv to see if it is bent out of shape or if it's just the angle I took the photo.
JPXU1
One of the nuts had been "punched" off during this whole mess, it has some pretty insane indents on the nut. Found it in the sump with the rest of the goodies. I removed it completely to see if the crank suffered any damage from one of the nuts coming off.
#19 Bruiser
Bruiser
  • 695 posts
  • Name:Bruce
Posted 14 June 2022 - 08:55 AM
That’s a shame mate, Did your valves and rocker gear escape the carnage at least?
#20 Heath
  • 18,309 posts
Posted 14 June 2022 - 09:46 AM
Ummmm... yowch.
#21 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 14 June 2022 - 11:00 AM
I haven't been game enough to pull the head off to fully inspect the valves however rockers seems a-ok and the valve stems seem okay from what I can see down the intake/exhaust ports and what sticks out near the rockers.
Absolutely spewing if there's damage head was only reco'd 4 weeks ago. 161 YT head too
#22 v6 torana
v6 torana
  • 493 posts
  • Name:Peter
Posted 14 June 2022 - 12:26 PM
I have rebuilt countless red motors and have never seen a camshaft failure like yours (not saying it isn't possible). You mentioned in post# 19 "One of the nuts had been "punched" off during this whole mess, it has some pretty insane indents on the nut. Found it in the sump with the rest of the goodies".
Is the conrod cap bolt (that the nut came off) sheered or has the nut worked its way loose and jammed in the camshaft causing the failure ?
#23 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 807 posts
  • Name:JASO
Posted 14 June 2022 - 12:32 PM
Is it a possibility, that the wayward bigend nut has come off and jammed somewhere in the cam workings?? (being so beaten up - insane indents)
#24 Bruiser
Bruiser
  • 695 posts
  • Name:Bruce
Posted 14 June 2022 - 01:11 PM
That’s what I was thinking, too
If there is none of the big end bolt remaining in it’s nut
it hasn’t broken, it’s unscrewed itself and flown off like a bullet.
Are there dings in number 2 crank counterweight right next to the big end bolt?
Hope I am just seeing things
Good news that the rockers are ok. How do the pushrods look?
The valve gear must have had some sort of rude shock
if it was enough to smash 2 lifters to pieces
#25 avoidev
avoidev
  • 32 posts
  • Name:Josh
  • Car:HZ
Posted 14 June 2022 - 01:41 PM
This is quite possible, I haven't really given it a full autopsy yet. I'll have a squiz and maybe post a picture of the nut this arvo.
I'm not gonna pretend I know exactly what I'm doing, this was my first time ever rebuilding a motor but I tried my best to follow the holden workshop books to a T.
The bigend nut coming off is another theory besides a lifter failing and jamming up the cam. When I rebuilt it I replaced the existing bigend bolt and nut with brand new ARP ones.
I found 2/12 pushrods laying in the sump when I removed it. Seems as straight as all the others. They are brand new 161 pushrods from crow.
There is a bit of damage to on of the counter weights, and two of the cam bearings suffered heavy damage.
Edited by avoidev, 14 June 2022 - 01:44 PM.
