Are slotted rotors worth the extra $
4 replies to this topic
#1 neglectedtorana
neglectedtorana
  • 1,057 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 14 June 2022 - 06:11 PM
Hi All,
I am looking at changing my rear disc setup and using different rotors to the current ones. I have VN front and rear rotors and was going to change to the DBA020 on the rear with a Wilwood caliper to match the front calipers. If I go slotted I will replace front and back so they match.
Although mostly a cruiser I like a fun drive on a windy road and hope to do some track days and hill climbs when work calms down.
Is it worth the extra cash for slotted rotors?
Do they get rid of heat better and consequently resist warping if used spiritedly?
The price difference is about $80 per pair for front or back.
Interested in any feedback if slotted are generally an improvement or just a visual treat?
Cheers, Tom
#2 Statler
  • 6,332 posts
Posted 14 June 2022 - 06:25 PM
Yes.
#3 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 14 June 2022 - 09:37 PM
Vt - vy rotors are bigger & clear 15" rims, on a commodore or statesman v8, the size definitely makes a difference in the braking efficiency.
#4 neglectedtorana
neglectedtorana
  • 1,057 posts
  • Name:Tom
Posted 15 June 2022 - 07:19 AM
Thanks gents, I was probably going to bu slotted and needed a push.
Plus at the moment they are 20% off
#5 ozyozyozy
ozyozyozy
  • 953 posts
Posted 17 June 2022 - 10:05 PM
They dont affect heat rejection.
Slots are to wipe the surface of the pad clean, help remove the gas build up between the pad and rotor.
Slots do help.
You will find the limits of that size of brakes doing track days.
Edited by ozyozyozy, 17 June 2022 - 10:05 PM.
