Triple SUs ID
18 replies to this topic
#1 avoidev
avoidev
  • 26 posts
  • Name:Josh
  • Car:HZ
Posted 21 June 2022 - 02:45 PM
Hey All,
Just hoping to get some information on these triples and the "armours" manifolds.
I've looked for the usual tags that are on these, but they don't seem to have any.
Thanks,
Josh
Attached File  20220327_122629.jpg   324.5K   3 downloads
Attached File  20220327_122635.jpg   304.38K   3 downloads
#2 Bruiser
Bruiser
  • 252 posts
  • Name:Bruce
Posted 21 June 2022 - 03:15 PM
Looks identical to my hs6 set from that angle.
Got a picture from more front on?
#3 warrenm
warrenm
  • 2,011 posts
  • Car:1972 LJ Torana
Posted 21 June 2022 - 10:23 PM
Look like HS6 1 3/4", the Armours manifold doesn't look like a Torana version.
#4 claysummers
claysummers
  • 2,245 posts
  • Name:Clay
Posted 21 June 2022 - 11:46 PM
Pardon my ignorance but I am curious as to why all the after market manifolds make the carbs slope upward? Alright for SUs with adjustable float bowls, but won’t work with zenith strombergs?
#5 S pack
  • 14,825 posts
Posted 22 June 2022 - 12:27 AM
Prob designed with SU's in mind, not CD Stromberg's. Also lifting the carbs would give better clearance with tubular headers/extractors.
#6 RallyRed
  • 6,971 posts
Posted 22 June 2022 - 06:32 AM
maybe also help with inner guard clearance? those fuel bowl thingos sit pretty low.
#7 I'm a Red Motor fiend
  • 711 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 22 June 2022 - 06:37 AM
Spot on Warren.
#8 warrenm
warrenm
  • 2,011 posts
Posted 22 June 2022 - 06:46 AM
It was for inner guard clearance
This is a "Torana" version, which flattens the carb a bit to clear the bonnet.
Attached File  000208 (600 x 450).jpg   79.06K   2 downloads
#9 claysummers
claysummers
  • 2,245 posts
  • Name:Clay
Posted 22 June 2022 - 06:53 AM
Thanks fellas, but no one duplicated the factory setup so we could run cd strombergs on afyer market manifold? I ask because a car on the FB EK forum modified after market so he could run the strombergs.
#10 Bruiser
Bruiser
  • 252 posts
  • Name:Bruce
Posted 22 June 2022 - 12:31 PM
What exactly is it about the armours manifolds that make them so much better than
the common lynx type?
Difficult to measure it while installed,
but my lynx one is pretty close to 145mm in a straight line
across the top to the outer machined side of the flanges.
Can’t measure exactly to include the bend in the shape, but that must go close.
How much longer is the armours?
Is the taper in the runner much different, or the runner volume?
Have heard talk of the balance pipe volumes making a difference too,
but no understanding of that so far
#11 Bruiser
Bruiser
  • 252 posts
  • Name:Bruce
Posted 22 June 2022 - 12:38 PM
Do those cabs have the wax stat type jet assembly?
A lot of the pommy guys replace the expanding pellet with 2p coins
Never noticed it ever being mentioned here before
Perhaps that setup is uncommon?
*carbs*
#12 warrenm
warrenm
  • 2,011 posts
Posted 22 June 2022 - 10:47 PM
The SU is a better carb, in my opinion, also available in 2" & rare 2 1/8", so leave the Stromberg for the genuine XU1's.
#13 claysummers
claysummers
  • 2,245 posts
  • Name:Clay
Posted 22 June 2022 - 11:51 PM
What about Weber style Warren?
#14 warrenm
warrenm
  • 2,011 posts
Posted 26 June 2022 - 06:52 AM
I haven't play with Weber/Delorto carbs much, but they seem to give good results for circuit racing etc. but not that much of an advantage with drag racing.
#15 avoidev
avoidev
  • 26 posts
  • Name:Josh
  • Car:HZ
Posted 28 June 2022 - 03:07 PM
G'day gents, apologies about the delay.
Here's above and front images. If anyone has any info on the armours intake manifolds too that'd be awesome, I can't seem to find any info on them at all.
Attached File  RUID65708fd6090448a5a9aa04ccd53d8456.jpg   135.83K   4 downloads
Attached File  RUID99a668e62f674023a09bb8b2a63d7e44.jpg   167.01K   3 downloads
#16 Bruiser
Bruiser
  • 252 posts
  • Name:Bruce
Posted 28 June 2022 - 05:45 PM
No waxstats on those jets
Hang on to your pennies for a rainy day.
The manifolds are pretty popular around here,
might fit under the bonnet of your hz if that’s where these are going
#17 warrenm
warrenm
  • 2,011 posts
Posted 28 June 2022 - 10:50 PM
Warren Armour cast the manifolds, he lives on the NSW south coast, originally from Sydney area(Sylvania seems to ring a bell). What info are you after?
#18 avoidev
avoidev
  • 26 posts
  • Name:Josh
  • Car:HZ
Posted 30 June 2022 - 04:06 PM
Was really just seeing if they're a good set I'm pretty new to all this stuff.
Bruiser really answered the two questions I had, do you think they'd fit under a bonnet of a HZ and are they good. So really both boxes have been ticked off.
I had to google what a waxstat was, and if it was better to have the SUs with or without them. Which from a quick google its better to have them without like I already do.
Thanks,
J
#19 Bruiser
Bruiser
  • 252 posts
  • Name:Bruce
Posted 30 June 2022 - 05:04 PM
There was a recent discussion here about how much power 1.75 su’s could support.
Seems they would be ok for mild to fairly hot motors
If you have them in good nick and sorted to your motor
I can’t see why they wouldn’t be bloody good
**Don’t take my word as gospel about them fitting, Josh
I am making a fairly guessey assumption about a big old hz lid having enough height for those,
I’m only going on red 6’s looking so teeny tiny in those engine bays
I don’t actually know from experience.
I’d be making measurements of them outwards and upwards,
drawing mad professor builder’s diagrams on scrap gyprock then checking against the bonnet line
- to save the agonising pain of your bonnet not closing after all that work
I am only just a few steps ahead of you here, recently rebushed and installed
my set that I gave up on years ago. I couldn’t get them to run well, and gave up back then.
Was going to sell them off, but got inspired by all the talk around here.
Used heaps of the advice I found, set them up as fussy as possible on the bench,
and they started right away - ran well too! (besides a high idle and a few leaks)
The rave up is no joke either, I had a 455 Holley vac before and these things were definitely
worth the effort. Makes a lot more power, and my plugs are the cleanest they have ever been.
At the point of setting up the mixture settings/needle choice to find a few more k’s in a tank.
They’re awesome, I’m having a great time playing with them, and when blokes say
“They tune well when you don’t cut corners and rebuild everything right”
That’s the key to keeping your hair intact
After all that, what plans are you hatching with yours?
