Hi guys
Bout to do the exhaust on lh running a 186 looking at 2 1/4 system what type or brand of muffler would I use.
Thanks Derek
Posted 13 August 2022 - 02:26 PM
Hi guys
Thanks Derek
Posted 13 August 2022 - 04:27 PM
Posted 14 August 2022 - 03:44 PM
The hotdogs need to be up front as close as possible to the engine to make a difference. Took 9db out of my LX sedan when fitted one to each side of the twin system.
Posted 15 August 2022 - 12:29 PM
A single glass pack would generally be the go if you want it to sound a bit sporty and it's a very mild motor.
If the motor has a lot of cam and compression, you may want something that'll work a bit harder to quieten it.
If has resonation making a yucky noise at lowish rpm, a resonator in the front half of the exhaust will help as Rexy has said above.
Some of the best sounding cars that have no business sounding as good as they do, just have simple mild steel mega cheap Super Cat mufflers. I assume you can still buy them? Although the times that I've been to Super Cat recently I've only bought Magnaflow products in stainless.
