TORANA LJ (1973)
22 June 2011 - 04:39 PM
Holden Torana (1978)
  • Vehicle Owner:
  • Date Added: 02 December 2008 - 07:38 AM
  • Date Updated: 27 April 2009 - 09:02 AM
  • Color: Turquoise
  • Price: --
  • Odometer: --
  • Body Style: hatch
9 inch diff, 3.55 LSD 28 spline reco'd and new wheel bearings. All blasted & 2 pack.
New rear sway bar, pedders comfort and springs. HZ reaction flange with torana rear calipers.Discs machined and new pads/handbrake cables. New heavy duty custom tail shaft.
Cross member stripped/blasted & 2 pac gloss black. All new bushes/ball joints. Pedders springs/shocks up front. Heavy duty sway bar. HZ girlock calipers (reco)/ new pads/discs wheel bearings and new VL ventilated dics. All new brake lines/hoses front to back.
New tunnel, connecting beams, clutch pedal mods, control arms boxed/painted/new bushes.All weak ares in chassis made strong. Front rail repaired and twist fixed. Floor painted flat black.
RB25DET engine and R33 5 speed gear box fitted using modified CRS gearbox cross member on trimatic  gearbox rubber. Standard UC engine mount rubbers on CRS engine plate adapters. Genuine USA nissan rear hump sump modified to suit UC.
RB25DET standard turbo, intercooler, air box, computer and harness. VL fuel pump and damper at rear. 3" exhaust from dump pipe, hi flow cat and muffler/resonator.
Excedy heavy duty clutch, new rear main, camshaft and crankshaft seals. New timing belt (blue one). New plugs and rocker cover gaskets. All new drive belts. Will be using R33 air con pump with UC air con.
Suzuki swift GTI recaro seats and custom interior. All sitting on VYSS 17" rims..
Much more to list, just can't think.
  • 736,824 Views
