Holden Torana LJ GTR (1973)
24 October 2014 - 07:19 PM
Holden Torana (1971)
  • Vehicle Owner: Anthony
  • Date Added: 28 September 2008 - 08:46 PM
  • Date Updated: 25 September 2011 - 10:17 PM
  • Color: spray putty
  • Price: --
  • Odometer: --
  • Body Style: sedan
what started off as a quick restoration has now turned into a full blown restoration.
Body: completely seam welded chassis, carbon fiber bonnet to save weight (will get painted to the same colour as the car ), 4 point roll cage for strength and mini tubbed, all rust repair work was done by myself.
Engine: 3.3 black, decked and O-ringed block, standard counter weight crank, romac balancer, YT flywheel, high energy sump with external pick-up, starfire rods, JE forged pistons 11.5:1 comp, completely balanced rotating assembly,roller solid cam [email protected] .650 thou lift, J-ZED head flowed to 700hp, YT roller rockers,6x EFI hardware 52mm tapered throttle bodies, MoTeC M84 ecu/CDI unit with MSD dizzy and to top it off a hit of nitrous.
Driveline: fabricated bellhousing to fit TREMEC TKO 600 gearbox and fully optioned nine inch diff with strange alloy center, axles and 4.11 gears.
brakes: Wilwood all round including master cyl and proportioning valve
  • 736,090 Views
