Oversized Pistons or rings?
_73LJWhiteSL_
Posted 10 October 2006 - 06:46 PM
just a question, when i build and engine and the block needs to be bored out (scratches etc) do i get oversized pistons or standard pistons and oversized rings?
Do oversized pistons even exsist?
Another question, in a street motor is it worth the extra money for 'race' piston or just use the standard ones?
Combo is at this stage: Red block, blue crank, blue rods, mild cam (27/67 or 1800- 5300RPM) probably yella terra head or ported 161 head, running on straight gas.
Steve
_CHOPPER_
Posted 10 October 2006 - 06:51 PM
[EDIT] I need to learn to type better!
Edited by -CHOPPER-, 10 October 2006 - 06:53 PM.
Posted 10 October 2006 - 11:07 PM
I am having thoughts with my LJ of using the original red 173 block and all the bits off the blue 2850 to get around rego dramas.
Posted 11 October 2006 - 12:00 AM
Buy your pistons and give them to the machinist to measure.
_[BOTTLEDUP]_
Posted 11 October 2006 - 03:42 AM
Putting in better quality pistons is definately a good idea, although what is available for a Holden 6 isn't a 'race' piston by today's standards. Precision Motorsport and ACL both do good performance pistons for the Holden 6, if you can get them with the thinner rings, these have less drag on the bore and better ring seal at high revs. Moly coated top rings are desirable but not essential, I always get file back rings so I can get the end gaps exactly correct.
I'd also get new cam bearings installed at the same time, and get the mains tunnel line honed.
_jklumpp_
Posted 11 October 2006 - 12:12 PM
The ACL "Race" piston only comes to suit a 202 (made for the HQ's), so you can only get a 'Duralite' for the other engine sizes - My engine is semi-race, and my engine builder reckons the Duralite will be fine.
_73LJWhiteSL_
Posted 11 October 2006 - 07:13 PM
I was comtemplating ACL Race pistons, rather than using the standard ones.
I was definately planning to get the engine and crank (i assume the crank can be balenced by itself and the engine balenced as a whole?) balenced up so it spins up nicely.
I have comtemplated the blue head option, but i am planning to stick a hot red head on, and modify a VK EFI Manifold to fit a 9 port head.
Steve
Posted 11 October 2006 - 07:34 PM
If it was me I would modify a 12 port head (bigger valves) and leave the manifold alone....This manifold developes positive pressure when used in conjunction with the black 12 port head....something i am sure you will lose by trying to stick it on a red head.
Posted 12 October 2006 - 01:17 AM
_jklumpp_
Posted 12 October 2006 - 01:18 PM
_73LJWhiteSL_
Posted 12 October 2006 - 06:30 PM
With the VK EFI thing i am sure the manifold will work better than the redline manifold i am running at the moment cause the EFI inlet is more balenced. And it shouldn't cost too much to get a couple of manifolds and give it a go. I am pretty sure dad will be able to get someone to do the work for me farly cheap.
I am not keen to stick a 12 port head on, cause unless i am incorrect it means new extractors, and if i put my new motor in and have problems its not as easy to ripp it out and stick the 173 back in. I have to change extractors and muck around a lot more than if i was runing 9 port heads on both the new motor and my exsisting 173... it is a daily remember
The other disavantage i was told is you can't stick unleaded valve seats in blue and black heads cause it goes through into the water jackets. Can anyone confirm that one?
Steve
Edited by 73LJWhiteSL, 12 October 2006 - 06:33 PM.
Posted 12 October 2006 - 06:44 PM
fair enough argument re extractors..but you could get a stock blue at the drop of a hat...the VK efi manifold is certainly better than the 3 runner cain or lynx...it will be interesting to see your results.
Blue and black heads get modded (gas seats) everyday..never heard of them breaking thru..it happened to me on a set of YT 308 heads...you just loctite them to seal them.
Posted 12 October 2006 - 06:45 PM
_73LJWhiteSL_
Posted 13 October 2006 - 06:36 PM
As i said above i want to avoid boring unless it is necessary, which means i can bore it a few time if i need to, which in theory means the block should do me quite a few years.
I don't mind if i spend a little bit of money on a modified EFI manifold to get it to fit a 9 port head and it doesn't work much better, but i think it will work better, even if its not as good as with a 12 port head.
thanks again
Steve
Posted 14 October 2006 - 10:24 AM
_73LJWhiteSL_
Posted 14 October 2006 - 05:50 PM
I reckon its got maybe 10 kws more with the gas system.
Steve
