253 v8 thermo fans
_chevy_253_torana_
Posted 16 October 2006 - 10:56 PM
the fan on the 253 in the lh is a bit of a weird looking thing as it sits high up very high infact above the radiator top (talk about dangerous!!!)
so im tempted to install a thermo fan to be safe aslo to reduce the risk of a fan blade through the hood
what size thermo fan/s would people recomend for a stocko 253 with a 2barell carby
Posted 16 October 2006 - 10:59 PM
Posted 17 October 2006 - 12:19 AM
_devilsadvocate_
Posted 17 October 2006 - 06:09 AM
Perhaps get hold of an original fan guard that bolts to the hood latch/support panel.......a 2min fix....and cheaper.the fan on the 253 in the lh is a bit of a weird looking thing as it sits high up very high infact above the radiator top (talk about dangerous!!!)
Posted 17 October 2006 - 10:55 AM
You can expect to pay around $300 - $400 for a thermo fan setup. If you do decide to go thermo then the Ford Mondeo or AU falcon fans are the best setup.
Over the last 16 years I have had twin Craig Davis fans without shrouds, twin Craig Davis fans with shrouds and currently have Ford Mondeo fans on a aluminium radiator as the Ford AU fans would not clear my Air Cond.
Andy
Posted 17 October 2006 - 12:50 PM
try about $150You can expect to pay around $300 - $400 for a thermo fan setup. If you do decide to go thermo then the Ford Mondeo or AU falcon fans are the best setup.
Posted 17 October 2006 - 10:38 PM
What can you buy for $150?try about $150
The $300-$400 was for new AU Falcon or Mondeo fans, relays, thermostat and wiring.
_DocDamage_
Posted 17 October 2006 - 11:53 PM
_devilsadvocate_
Posted 18 October 2006 - 11:19 AM
Do consider that the new cheaper ones are probably not the genuine Ford article(Bosch motors etc) and may not be as good...........something that only lasts 2 years may not be so cheap afterall..........however, the aftermarket article maybe just as good.............who has had some of the aftermarket ones longer than 3 years?
Posted 18 October 2006 - 12:03 PM
$145 gets you a set of AU thermo's from the wreckers, $5 get you 2 relays from jaycar, another $5 for 2 blade fuse holders and fuses and around $40 for a temp sender and chuck in another $5 for some wire, there is $200 well spent
Edited by makka, 18 October 2006 - 12:04 PM.
_LHoon_
Posted 18 October 2006 - 02:43 PM
_devilsadvocate_
Posted 18 October 2006 - 03:48 PM
Chances are though if this was fitted to a car without engine management it would be very annoying when the fans kick in as it would require having a much higher than necessary idle speed to stop the motor dying when the fans kick in. The AU fans put an ~2hp load on the motor......if the alternator is up to it.
Posted 18 October 2006 - 04:51 PM
