OT: Help needed With Hyundai Excel
Posted 02 November 2006 - 09:55 AM
We've just begun having some problems with simmo's excel.
Now its a 99 model Hyundai excel, 1.5L powerhouse.....
Before i get the "sell it.. buy a torry" comments the car was bought new and has been looked after and really hasnt given us ANY greif till now!
OK... So simmo takes it to work monday morning.. and 20 minutes into the drive ( and near central railway station) it cooks... to the point of steam blowing out...
Got it home and found that the fans are not working... Either of them!
I tried to jump them by putting a wire direct to the terminals and to the battery and neither of them turned at all. Not even a spark at the battery terminal!
I'm guessing the fan motors are shot.
I then measured voltage at the connector ( incoming from the loom) at the air con fan. ( turned on aircon.. and measured bvoltage at connector) found it to be 14.4V!!!
Measured this at the battery too.
My concern is that the voltage regulator in the altenator has died giving full voltage to all components.. Causing the fans to burn out.
Can anyone confirm this?
Ive checked that no fuses are burnt out, but i cannot figure out how to get the relays to come out of the relay box!! Ive ripped the "lid" off one of the relays already... thankfully they just clip back on!!
Any help appreciated!
_devilsadvocate_
Posted 02 November 2006 - 09:05 PM
When you say you jumped the motors, there is only two wires going to each fan and you connected them straight to the battery and nothing happened? sounds like they are both shot........but it would seem unlikely two of them would fail together........or perhaps one failed a while ago and it has been surviving on one and it has now just failed.
Edited by devilsadvocate, 02 November 2006 - 09:07 PM.
Posted 02 November 2006 - 09:12 PM
that sounds like a reasonable answer. one could have went a long time ago, and the extra load on the single one has caused it to die over time as well.sounds like they are both shot........but it would seem unlikely two of them would fail together........or perhaps one failed a while ago and it has been surviving on one and it has now just failed.
is there anyway you can take it apart to see if its shagged? are they a similar setup to a davis craig setup? (two wires come off each fan?)
_DocDamage_
Posted 02 November 2006 - 09:17 PM
Posted 02 November 2006 - 09:33 PM
I'm willing to bet if you probe both wires to the fan they will both have 14.4 volts..no potential difference..it will be the ECU that switches the earth..and the coolant temp sensor that tells the ECU when to do it.
I would check fuse again (probe both sides of fuse) and locate which relay operates the fans...then find the Coolant temp sensor..check connection.
after that..well I wish it was in front of me....Its been a good 5 yrs since i have been under the bonnet of an excel.
_devilsadvocate_
Posted 02 November 2006 - 10:56 PM
I dont know about what is under the bonnet of an excel specifically, however, typically the ecu will control a high powered device by earthing the relay of the device(not the device itself) whether the relay then connects one side of the fan to the battery, or connects the other side to earth can be chosen to suit, however, having the relay switch to earth would always require a live wire going all the way to the fan and back to the relay, whilst this not going to be an electrocution risk....(as in the same way an old power point could be wired with the switch in the neutral wire) its certainly got more potential to cause problems when people are poking around with the wiring etc, than the other way around.........
Posted 02 November 2006 - 11:27 PM
they must be real cnuts as it went back to the auto lecky a few times, so maybe ask them first if they had excel probs
Posted 03 November 2006 - 02:02 PM
DA: The way you read my gobbldygook above was 100% correct.. I disconnected the fans at their connector and put wires directly to the battery and got nothing! I'm leaning towards shot fan motors. I tested the voltage with the motor running at the disconnected fan connectors.
FastEH: Is there a trick to getting the damn relays out? I cant seem to get them out of the holder!! Therefore i havent been able to test these yet!
Ive spoken with 2 Hyundai tenchicans and they both tell me that the fan motors are a common problem and there are revised fan motors availible from hyundai. I have JUST priced them... and for the radiator fan motor alone its $202.75 + GST.. and for the aircon fan motor its 270.75+GST!!!
I think i need a becks and a lie down...
Thanks again for the tips.. if i can get these relays out to test them i will do that before lashing out and smoking teh credit card for a couple of fan motors!!
Thanks to everyone!
Posted 03 November 2006 - 02:04 PM
I didnt allow the engine to heat up to test the radiator fan but i did try to bypass everything and test the motor by giving it 12V from the battery.
Cheers!
_devilsadvocate_
Posted 03 November 2006 - 09:32 PM
If that is so, it would appear that pulling relays etc is not going to achieve anything. To confirm, put a test lamp across the connectors if it goes on and off when you trigger the air then the circuit must be okay. To double check that it will run full power, wire in another fan or a high powered testlamp (50W spotlight) or similar.
Do the fans spin easily by hand? Any burnt smell at all?
Original parts replacement price ouch! Id be looking at anthing else that might fit, couldnt end up being too much worse than the originals!
_devilsadvocate_
Posted 03 November 2006 - 09:33 PM
Posted 04 November 2006 - 08:46 AM
I tested 14.4V at the connector with engine running which as you said proves to me that everything up to that point is fine ( voltage is getting TO the fans.. but theyre not doing anything with it!).
Ive spoken to 2 Hyundai mechanics who say that motors are a very common problem with these, and also that the voltage is within normal tollerance for that model AND that there is a revised fan motor to stop this problem occuring again.
I'm going to "Bash the plastic" because i simply cant wait to try and find aftermarket replacements and the car has to be running again ASAP.
The fans do spin easily by hand and theres no detecable burnt smell.
Thanks for the tips DA!
_Flamenco_
Posted 04 November 2006 - 09:26 AM
_devilsadvocate_
Posted 04 November 2006 - 02:01 PM
Well, I hope there isnt any hidden suprises when you go to fit the fans..I tested 14.4V at the connector with engine running which as you said proves to me that everything up to that point is fine ( voltage is getting TO the fans.. but theyre not doing anything with it!).
Its not clear from ^, but you did test that the voltage dropped to zero when you switched the air off with the engine running?
_CHOPPER_
Posted 04 November 2006 - 02:23 PM
Posted 04 November 2006 - 03:22 PM
DA: Thankfully i havent found any surprises! Ive just fitted up the replacement fan and fan motor and everything seems fine thus far! I'm buying replacement radiator hoses and of course more coolant tomorrow just as an added measure of safety ( Hey i'm here doing em.. why scrimp now!!)
I didnt check voltage when turning the A/C off with engine running, I didnt check that at all.
Chop: I had a really good think about this option and the reason i didnt go for it was that if this is a known problem then A) the wreckers are likely to have few fans from all the people like me wanting them...
I went to Peter Warren at Warwick Farm and spoke with a guy from their parts dept. I asked for replacement motors for these fans. He was able to tell me that a motor for the A/C fan was $270... BUT a complete replacement unit was only $160!! Saved me just over $100!!
I was really grateful that he steered me in the right direction!
Anyhow, When i fitted the new fans ( removed the radiator.. WAAAAY easier), I found that the A/C fan was defintiely SHOT.. you can hear the windings touch when you spin the blades! and i took the Radiator motor and with its leads touched it directly to the battery and got 1 revolution out of it! So I'm fairly confidene we've got the problem licked!
Just hope no other damage has been done... Will be doing a cooling system flush and putting in new coolant along with the new hoses and fingers crossed she'll be ok!
Thanks again for all teh advise and assistance!
