drop tank?
14 replies to this topic
#1 _lx304hatch_
_lx304hatch_
Posted 03 November 2006 - 02:48 PM
hey there guys, i use to have the planes to make a drop tank from a forem member it was full detail drawings that could be handed to any metal fab place so they could make it up for you just wondering does any one have them as i have missed place them and need to get one made up so i can put a intank pump for my 304efi pls help me :cry:
#2 hatchssv8
hatchssv8
  • 358 posts
Posted 03 November 2006 - 02:53 PM
I have a few pics you may be interested in. I will try and host them buy 6 pm today.
Set up is for injected motor
Cheers, Max
#3 Toranavista
Toranavista
    'Let There Be Rock' 1977
  • 2,862 posts
This should keep you off the streets :D
http://canberratoran...o/droptank.html
#4 _lx304hatch_
_lx304hatch_
Posted 03 November 2006 - 02:57 PM
thants help a fair bit but i did have one that had all the measurements and every thing full cutting list i nead the measurements to give to my local guy
email the other ones if u can mate [email protected]
Edited by lx304hatch, 03 November 2006 - 02:58 PM.
#5 _lx304hatch_
_lx304hatch_
Posted 03 November 2006 - 03:00 PM
:ZZZ: some one slap me across the head i didnt notice the bottom ones as they didnt load straight away thats exactly wat i needed thnxs heaps guys
#6 ls2lxhatch
  • 5,335 posts
Posted 03 November 2006 - 04:07 PM
lx304hatch,
I will be interested to see what you come up with. I have a Brown Davis tank and was planning remove the plate over the spare tyre recess. Fit the sirl pot inside and then replace the spare tyre plate with a flat plate which should leave enough room to mount the swirl pot pump and EFI pump.
If you are building the tank from scratch then you could look at fitting the pump from a VZ LS2. The standard Brown Davis tank is not deep enough by about 20mm and does not have any clearance above the tank. The VZ pump has a minimum depth of 240mm and needs 40mm clearance above for fuel lines. The VZ pump is around $250 from Holden including swirl pot and fuel sender. You can buy a weld in mount ring to suit from Castle Auto Elec for $120.
http://www.castleaut...igen3lhlxuc.php
#7 _lx304hatch_
_lx304hatch_
Posted 03 November 2006 - 04:45 PM
sorry to disapoint you im just running a pretty well stock vn v8efi and just thought that i want a drop tank and few guys at my work said they could make it if i get the plains and gear, was gonna put a stock vn v8 pump into the tank and a stock vn v8 out tank to suply the motor
#8 Dangerous
Dangerous
  • 948 posts
Posted 03 November 2006 - 05:34 PM
Gee ............It would be a shame if they only made one .............. HINT HINT :spoton:
#9 _Yella SLuR_
_Yella SLuR_
Posted 03 November 2006 - 06:55 PM
Another car with a Yella tank. Just understand that the drawings don't have the baffles inside the tank shown (couldn't measure them).
Edited by Yella SLuR, 03 November 2006 - 06:56 PM.
#10 ls2lxhatch
  • 5,335 posts
Posted 03 November 2006 - 07:14 PM
It is still worth considering moving the swirl pot into the tank instead of the boot.
If you need any additional measurements or pictures I will have my Brown Davis tank out of the car for the next couple of weeks.
#11 _Keithy's_UC_
_Keithy's_UC_
Posted 04 November 2006 - 06:08 AM
I should add my 2c to this one...
I have had a drop tank made up for my UC to suit a motor with fuel injection. It can be used for carburetted applications also.
The swirl pot inside has been welded to the tank itself, it's got an outlet on the rear for a VN V8EFI pump (which is fitted).
The problem i encountered fitting it all up is the fuel gauge sender unit. I couldnt put the knife in and twist (so to speak) and cut up the wiring to try and adapt it. I could run without a fuel gauge OR get an aftermarket VDO or Autometer unit, but i would like to stick with the factory gauges with regards to fuel and speed (i.e. i am not making a custom dash).
If you do figure out how to adapt this part, could you please drop me a PM. I know the Ohms on the VN V8 sender and the UC Torana with regards to fuel gauge are EXACTLY the same, but any other model torana is different. I'd be glad to see how it turns out.
Keith
#12 _Chamois hatch_
_Chamois hatch_
Posted 04 November 2006 - 07:29 AM
don't brown davis make drop tanks with, surge tanks already inside? im pretty sure thats what they told me last time i gave em a call.....they were only a couple hundred bucks dearer than the standard drop tanks. i should have a surge tank in my hatch and am seriously considering buying another brown davis tank to replace the one i curently have.....
instead of mounting a seperate thing somewhere and runing more fuel lines etc.
#13 ls2lxhatch
  • 5,335 posts
Posted 04 November 2006 - 11:24 AM
I bought a Brown Davis fuel tank with the 1/2" pickup and swirl pot which cost an extra $150. At the time I ordered the tank I was told the swirl pot was suitable for EFI and I did not know any better. A swirl pot and a surge tank are two different things.
The swirl pot in the Brown Davis tank is a set of baffles with a 1/2" pickup in the middle. The swirl pot is filled by gravity under normal conditions and the baffles slow down the emptying of the swirl pot during g-force events. When you pump fuel out of the swirl pot there is no return line back into the swirl pot instead the return line is via the standard fuel pickup.
A surge tank is typically a tall one litre tank with a pickup at the bottom, an input near the top and an overflow at the top. Fuel is pumped into the surge tank from the main tank using a low PSI fuel pump. G-force events have little effect on the surge tank because of the tall design. When the you pump fuel out of a surge tank to the engine any excess fuel is returned to the surge tank. Any excess fuel from the lift pump in the surge tank is returned via the top pickup to the fuel tank.
The typical EFI setup is to pump fuel at a constant flow rate and high PSI to the engine and any excess fuel/pressure is bleed off by a regulator and returned to the surge tank. If you were to use just the swirl pot in a typical EFI setup the swirl pot would be emptied in a few seconds during G-force events by the EFI pump as the excess fuel is returned to the main tank. The surge tank system however will not empty until the fuel has been consumed by the engine as any excess fuel is returned to the surge tank.
The typical carburettor setup only pumps fuel when the fuel bowl empties so the swirl pot will only empty as the fuel is consumed or gravity drains the pot.
I intend to remove the plate from the spare tyre area of my Brown Davis tank which has never been used. Install a surge tank and replace the spare tyre area plate with a flat plate which should leave remove to mount the pumps. I am not comfortable with the idea of having fuel system components inside the car. (boot/hatch)
#14 _Chamois hatch_
_Chamois hatch_
Posted 04 November 2006 - 11:31 AM
OK i new the difference between surge tank and swirl pot, but was under the impression that it was a surge tank incorporated into the brown davis tank.
Andy, make sure you take lots of pics when you do this little surge tank exercise as i would be most interested to see how you make it all fit, cause like you i dont want components of the fuel system in side the car.
looks like for now i'll just keep the drop tank topped up!
john
Edited by Chamois hatch, 04 November 2006 - 11:42 AM.
#15 _Keithy's_UC_
_Keithy's_UC_
Posted 05 November 2006 - 06:22 AM
Not bagging the BD Drop Tank, but if the Swirl Pot has been designed correctly, there is NO need for a surge tank. That's why i had my tank custom made. I know what's inside of it, and it's been made to suit a race application (if needed).
The same tank (obviously of different sizes) has been fitted to a HZ race/road car with injected 304, this car does not use a surge tank and has never experienced fuel surge at any tank level. He generally runs it at 1/2 tank when he races it - that's what swayed my decision to his tank. All they did was measure up all sizes and departure angles, and incorporate the swirl pot, then customise it to fit VN V8 pump unit. It cost me less to have it built than a Brown Davis tank would have cost me...
Keith
