installing rust repair sections
_chevy_253_torana_
Posted 09 November 2006 - 08:47 PM
with the monaro i have been thinking because i dont have a mig welder yet to get that glue they assemble the vt commos etc with and install the rust repair sections with this instead
anyone done this before ?? if so does it hold up and no want to drop or fall out ??
_Yella SLuR_
Posted 09 November 2006 - 08:54 PM
Can you borrow a MIG, hire one, or get hold of an oxy set?
_CHOPPER_
Posted 09 November 2006 - 08:55 PM
Posted 09 November 2006 - 09:05 PM
_Leakey_
Posted 10 November 2006 - 09:21 AM
The dreaded top part of the hatch area, in between the hinges has
pretty much gone to being paint only!!. I was going to get a piece
cut and grind out the rust, and weld this in, but as a crappy welder,
I was worried about warping the roof and making more problems
for myself.
So I thought as an interim, I might glue in a panel, plastic or metal,
that would keep the water out and stop further damage. Painted up,
and blended in [read bog] you would never know the difference.
I was thinking of using a liquid nails type adhesive, but will ring the
Sikaflex info line to see if they have a product that will suit. What you
described is the go. They probably supply it to GM.
Cheers, Leakey
_Oldn64_
Posted 10 November 2006 - 09:32 AM
Posted 10 November 2006 - 09:36 AM
How do you butt together a rust repair section with glue?
If you overlap there is going to be an high spot. Unless you fold in a rebate/step or something.
_Yella SLuR_
Posted 10 November 2006 - 09:49 AM
I believe most the panel beaters use stuff they call "Urethane". Whether or not that is it's true name or not is another story.
Posted 10 November 2006 - 02:17 PM
_Leakey_
Posted 10 November 2006 - 04:00 PM
I think most of the big side panels on coaches are also glued on.
- Leakey
_CHOPPER_
Posted 10 November 2006 - 05:21 PM
Posted 11 November 2006 - 08:45 AM
Yes, they are called "stretch" panels.I think most of the big side panels on coaches are also glued on.
_chevy_253_torana_
Posted 15 November 2006 - 10:20 AM
it costs 50 bucks a shot and il need a gun to shoot it out of (he wasnt sure on the price)
its the same stuff vts are glued together with
http://www.gmh-toran...opic=10491&st=0
theres one of the sections il be doing in there somewhere also gotta do the scuttle panels and a couple of other sections as well
that tab idea of the metal behind to beef it up sounds alright il have to talk to the boss about it tonight (dad)
if this stuff will hold il be leaning towards it cause migs are good but the as others have said the glue wont warp and wont trap in more rust
_CHOPPER_
Posted 15 November 2006 - 11:09 AM
I've got a couple of .22 rifles in the garage.it costs 50 bucks a shot and il need a gun to shoot it out of
Posted 16 November 2006 - 03:44 PM
Caulking gun, approx. $5 at Bunnings
Seeing you standing on your head squirting up side down and getting covered in black shit?
Priceless!
_CHOPPER_
Posted 16 November 2006 - 04:54 PM
_Yella SLuR_
Posted 16 November 2006 - 05:05 PM
Edited by Yella SLuR, 16 November 2006 - 05:05 PM.
Posted 16 November 2006 - 05:24 PM
Is this stuff sandable? i have heard there is a silicon or something that can be sanded and painted over...
Posted 16 November 2006 - 06:24 PM
Very CleverBlack sikaflex, approx. $18 at Bunnings
Priceless!
Posted 16 November 2006 - 07:21 PM
It is available in different grades, black is the strongest from memory, bunnings also have white which takes longer to dry.
For best results I would roughen up panels and prep them with metho.
Gloves recommended, clean up with metho before it drys.
Chopper: you could glue your panels onto your drag car with this stuff!
Might flex a bit though
#21
_CHOPPER_
Posted 16 November 2006 - 07:31 PM
#22
Posted 17 November 2006 - 07:08 PM
Chevy, just get a MIG. How the hell could you have a yard full of old cars and not have a MIG?
RIM
