253 rocker covers
11 replies to this topic
#1 _kaz from adelaide_
_kaz from adelaide_
Posted 22 November 2006 - 12:28 PM
the rocker covers on the 253 are shabby (but workable) . Are 253 and 308 same size? any others fit?
On the passenger side rocker cover it has the cap ontop then a hole at back that has a rubber grommet that is plugged shut with silicone, other side has hose connected to front goin to back of carby. What was the siliconed off hole used for?? If its not needed how do i properly close it off??
ta
XXKAZXX
#2 _timbotorrie_
_timbotorrie_
Posted 22 November 2006 - 12:43 PM
they are the same kaz!
the hole may have been used for a breather at some stage, does it have a PCV valve at all? or is that fitted on the other side?
:D
#3 _LX8VD69_
_LX8VD69_
Posted 22 November 2006 - 01:16 PM
the hole in the back of your rocker cover is for your pcv, as far as im aware the pcv was only on the passanger side, so perhaps you have 2 left hand side rocker covers. just get some chromies, that say 253 on them and you can still hook up a pcv with them as well :spoton:
#4 _kaz from adelaide_
_kaz from adelaide_
Posted 22 November 2006 - 04:20 PM
#5 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 22 November 2006 - 07:19 PM
the front hole on the drivers side goes to the carby, the rear one goes to the aircleaner
#6 _kaz from adelaide_
_kaz from adelaide_
Posted 22 November 2006 - 07:48 PM
ta muchly.
so would i be right in sayin the rear one is sealed off cause its not the original air filter??
#7 _nunganunga_
_nunganunga_
Posted 22 November 2006 - 08:18 PM
Yea thats right. Too help the crankcase breath properly you need a pvc in one tin connected to manifold vacunm somewhere and a breather hose/or breather cap in the other tin.
#8 _chevy_253_torana_
_chevy_253_torana_
Posted 22 November 2006 - 08:36 PM
yea if the back ones been blocked off probably been a conversion job iffy spot as i had the same prob and just swaped the rocker covers around on the 253 in my lh
253 heads are identical to 308 heads (lol trhis reminds me of a story some idiot saids to me the other day if you want to get a 308 really going bolt 253 heads on! )
personally i wouldnt go the tin styled rocker covers as the breather applications in them arent as good as the std covers are
just repaint the stockies or get the alloy ones
my 2 cents
#9 _kaz from adelaide_
_kaz from adelaide_
Posted 22 November 2006 - 09:23 PM
The 176 had a chrome breather cap filter thingy, but the 253 has a normal cap as per pic and the hole at the back of that rocker cover is the one siliconed shut. so instead of cap should it have a breather cap?
way toooooo many caps in that story :fool: :rolleyes:
the breather cap on the 173
Edited by kaz from adelaide, 22 November 2006 - 09:36 PM.
#10 TerrA LX
Posted 22 November 2006 - 09:34 PM
run the front one from the manifold to the cover with the PCV and the rear one from the cover to the air filter, as per standard.
#11 _kaz from adelaide_
_kaz from adelaide_
Posted 22 November 2006 - 09:41 PM
I'll have 2 check air filter 2 morra, dunno if it has a connector on it. ta
#12 _MRNOS_
_MRNOS_
Posted 23 November 2006 - 05:55 AM
I see you have gas....on the 253, did you just replace a V8 with a 6???
