Fuel Pump to suit triples
_troy_
Posted 05 December 2006 - 08:47 PM
_Oldn64_
Posted 05 December 2006 - 10:04 PM
_draglc_
Posted 05 December 2006 - 10:25 PM
keeps up now too with the v8.
was only about $115 from www.vpw.com.au
A1
_LoneOranger_
Posted 05 December 2006 - 10:51 PM
You need low pressure, high flow.
The "Carter" is a rotary pump, so you will get constant flow without the hammering at the needle and seats. Plenty of fuel volume.
A better system would be to run a return line to the tank.
You won't need to use a pressure regulator.
I find this the best way to run Webers too.
Ferrari used this system for the Webers on their old non injected cars too.
John.
_gtrtorana_
Posted 06 December 2006 - 08:14 AM
_dave720gtr_
Posted 06 December 2006 - 09:22 AM
i am using the latest holley HP125 very quiet pump 120gph at 7 psi
Edited by dave720gtr, 06 December 2006 - 09:22 AM.
_Aquarius - LC_
Posted 06 December 2006 - 10:32 AM
I've also been using a Carter 75gph for 3 1/2 yrs now, i'm very happy with it! I'm running tripple 1"3/4 SU's,regulator set at 3psi.
Posted 06 December 2006 - 11:04 AM
_troy_
Posted 06 December 2006 - 03:16 PM
_troy_
Posted 06 December 2006 - 03:22 PM
Posted 06 December 2006 - 05:35 PM
_LoneOranger_
Posted 06 December 2006 - 05:53 PM
Rare spares have them.
_gtr161s_
Posted 06 December 2006 - 06:12 PM
_troy_
Posted 06 December 2006 - 06:27 PM
_LoneOranger_
Posted 06 December 2006 - 06:45 PM
If not, it's a good idea to use a regulator, But try without first.
What damages the seats on the carbs is the hammering from the mechanical or electric pumps. (especially Facet pumps) The SU Fuel pump only allowed the fuel to be pumped once the pressure dropped.
John.
