radiator overflow hose
Posted 02 January 2007 - 02:07 AM
that is the overflow pipe, not the return pipe thanx.
cheers.
Posted 02 January 2007 - 04:34 PM
_Monkey_
Posted 02 January 2007 - 04:43 PM
and on my daily hq i use teh good ol 600ml coke bottle
Posted 02 January 2007 - 05:28 PM
Posted 02 January 2007 - 08:19 PM
Posted 02 January 2007 - 08:41 PM
Posted 02 January 2007 - 08:51 PM
_devilsadvocate_
Posted 02 January 2007 - 09:45 PM
There may be a half inch hole in the top of the cap on the reservoir? On all the torries Ive seen this looks like its been drilled in there afterwards, sometimes when the rad cap first releases it can put out quite a burst and they perhaps did this to stop the lid being blown off the container completely, or perhaps the containers didn�t handle the pressure. They are a bad design with the inlet directly below the lid. Should have been designed with the lid and inlet skewed and then a simple vented cap could have been used. To stop it flying through the hole, I use a piece of foam as a baffle.
As a side note, on one of our torries, we used another windscreen reservoir as the overflow tank, only the lids were different�..well so I thought����10 years down the track��.the coolant would go into the container, but never get sucked back in the rad again, collapsing the hoses etc. After much headscratching the prob was found to be a small mesh filter in the bottom of the reservoir that was clogged, which is only fitted to the washer reservoir
Edited by devilsadvocate, 02 January 2007 - 09:48 PM.
_Monkey_
Posted 02 January 2007 - 09:53 PM
Use a recovery cap on your radiator and when the coolant cools it will draw the coolant back into your radiator.so whats suppose to happen when the bottle fills, just let it spew all over the engine bay?
Posted 02 January 2007 - 10:04 PM
im sure there is a few a9x owners who would not appreciate boiling hot coolant infected water spewing all over the engine bay.
anyway, i take it holden never intended the bottle to overfill hence no hose to ground.
i assume someone drilled a hole in my green cap and once had a hose there.
i too will try fit a hose here but need one with a 90deg bend in it to fit properly.
thanx for the responses guys.
_The Baron_
Posted 03 January 2007 - 11:13 AM
There is a tapoff point (Vertical) at the top for any excess water to flow out off it. Cut the hole open and fit a tube to this point and pass the tube through the gap in the engine bay side wall.
This is the A9X setup that directs overflow down onto the road and not spewing into your engine bay.
The washer bottle style has it's problems as discussed above.
Posted 03 January 2007 - 08:00 PM
The A9X one has the overflow, the standard LX one does not, this is the A9X style, the top hose is overflow, the hose at the bottom front is from the radiator
_The Baron_
Posted 04 January 2007 - 08:26 AM
Yes, I said "overflow" in relation to the discharge from the radiator going to the bottom connection on the bottle. Maybe I should have said radiator discharge.
Posted 04 January 2007 - 09:55 PM
_Yella SLuR_
Posted 04 January 2007 - 10:04 PM
Posted 04 January 2007 - 10:22 PM
Posted 08 January 2007 - 08:57 AM
I pulled mine out as the smaller hole clogged too easily, the grommet was getting brittle, and the cap kept getting blown open anyway.
I have only seen three of these grommets still in cars, including mine.
Posted 08 January 2007 - 11:11 AM
Just a dim memory (as most are these days), but I seem to recall seeing at least a few overflow containers with a small groove in the lip that the cap fits on, not in the cap itelf. This would have been enough to let any pressurised air out.I just mean't relief for the air trying to escape/vent when the bottle starts to fill, and allow air back in when the radiator sucks the fluid back in. I don't think they had a hole in the cap at all from new, or if they did, maybe it was simply too small.
Posted 15 January 2007 - 04:16 PM
This is taken from a service letter:
It has been established that the pressure venting of the radiator coolant reservoir is insufficient and under severe after boil conditions, pressure can build up in the reservoir.
Therefore it is recommended that in service the size of the vent hole in the reservoir cap is increased from .187in. (4.7mm) to .385in (9.5mm).
This change is now in effect in production.
Edited by tinkers, 17 January 2007 - 04:29 PM.
Posted 15 January 2007 - 06:41 PM
#21
Posted 15 January 2007 - 07:35 PM
#22
Posted 15 January 2007 - 07:38 PM
My coolant capacity is pretty big (16L) and the overflow tank is only just big enough by about 1/2L so I have to be careful not to overfill or it does spray everywhere. Was more of a prob in Canberra where the engine saw a 15 degree larger variation from cold to hot and I did manage to overfill it once, not a problem in Brissy though. Still didn't pop the cap off when I did overfill it though, just sprayed a bit of alien blood around.
I would imagine the boil over scenario is where you would run into problems (as mentioned above) as during normal warm up, the coolant expands slowly anyway.
Enders, mine didn't have that grommet when I bought it from Holden.
M@
Edited by Toranamat69, 15 January 2007 - 07:39 PM.
#23
Posted 15 January 2007 - 07:48 PM
#24
Posted 16 January 2007 - 11:12 PM
I'll get a pic for you tomorrow.
M@
#25
Posted 16 January 2007 - 11:15 PM
