Bleeding the Clutch on a VYII Gen 3
9 replies to this topic
#1 _jklumpp_
_jklumpp_
Posted 14 January 2007 - 06:34 AM
I went to bleed the clutch on the commodore today (VYII SS 6sp Man), but I cant find the slave cylinder!!
There is a hydraulic line that goes inside the bellhousing, which i assume is feeding the slave cylinder....I cant even see the clutch fork!
It appears that everything is inside the bellhousing - but How the F@#$ do I bleed the line?????
#2 _2wild4u_
_2wild4u_
Posted 14 January 2007 - 03:30 PM
with difficulty, the slave actually runs behind the thrust bearing, if you look at the top of the passenger side of the gearbox there is a hole at the top, where the bleed screw is, it sits a bit inside the bellhousing but you should be able to feel it, its a 11mm hex head which you need to loosen to bleed, best to do it with a quarter drive deep socket, hope this helps
#3 _jklumpp_
_jklumpp_
Posted 14 January 2007 - 06:34 PM
Thanks for that wild - so is that the hole that the hydraulic pipe goes in?
So do you loosen it, the put the bleeder hose on?
#4 rodomo
  • 18,051 posts
Posted 16 January 2007 - 02:56 PM
Sounds like a nightmare, and you would have to ask yourself WHY? :fool:
#5 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 16 January 2007 - 04:31 PM
Hmm, on my VT it's out in the open. I wonder why they changed it.
#6 Evan
Evan
  • 1,287 posts
Posted 16 January 2007 - 10:40 PM
its such a stupid idea haivng it there, my mates slave is leaking,and it put oil allover his new $400 clutch.
Spewing
Evan
#7 _the gts_
_the gts_
Posted 22 January 2007 - 10:05 AM
Yea mine is actually in holden today getting a leak fixed. Apparently there is a fix for leaky cylinders, so if you are playing around that area make sure you do the fix. cos i can assure you its a pain in the ass trying to drive without the clutch in these new motors.
The computer keeps the revs up when changing gears, apparently to help keep gearchanges smoother. makes gearchanges take a long time when not using the clutch.
#8 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 22 January 2007 - 05:40 PM
hmm interesting, mine doesn't do that, but it's the old Holden 220i motor
#9 _rorym_
Posted 22 January 2007 - 05:42 PM
Take it to a Holden Dealer...Problem solvered! :clap: :spoton:
#10 _jklumpp_
_jklumpp_
Posted 22 January 2007 - 07:10 PM
^^^Rory, have you not read the other post about Holden Dealers????
