15x10 Hotwires for front wheels
_AquaSLR5000_
Posted 17 January 2007 - 10:49 PM
Posted 17 January 2007 - 11:25 PM
Posted 17 January 2007 - 11:50 PM
Any more than 4.5"back spacing and your rim will be hitting the top ball joint &/or the upper control arm (with the wheels straight) &/or the lower control arm at the back on full lock.
This leaves you having to run 5.5" of rim to the outside and will result in a nasty scrub radius about 1 to 1.25" further out per side than the original torana front end. That will also make it very close to the lip on the rear edge of wheel arch even if you do bend it over - depending on what tire size you run.
HQ stub axles or CRS drop stubs will allow more room to the top control arm and balljoint and the repco sealed top balljoints would help too, still going to be close in the other places though.
I have heard of people doing some cutting and welding to make room behind the wheel where the lip is (more than just removing the lip) but that scrub radius won't be nice for handling and steering.
I ultimately plan to run the ZR1 corvette size up front (275/40-17) but I have lots of things to do first to allow that to happen - I also plan to use 9" or 9.5" rims, not 10's
M@
Posted 18 January 2007 - 12:09 AM
Posted 18 January 2007 - 01:06 AM
M@
_HatchmanSS76_
Posted 18 January 2007 - 05:25 AM
Posted 18 January 2007 - 10:37 AM
225's abit small isn't it ?
Didn't they run something abit bigger (but lowish profile) on the track cars
_HatchmanSS76_
Posted 18 January 2007 - 12:14 PM
Posted 18 January 2007 - 03:05 PM
Posted 18 January 2007 - 05:56 PM
Are you sure they are 10's? you measure to the inside edge where the tire bead sits for rims not the overall width - or is the size marked on the rim?
M@
Posted 18 January 2007 - 06:05 PM
Funny thing though..Grices car and other had the same offset..appeared that only HDT had different offsets from all the pics I have looked at.My 15x10's will fit front and rear with the right tyres, but originally the race cars needed a different offset front to rear. Look at the Brock A9X's for example.
Posted 18 January 2007 - 09:22 PM
_AquaSLR5000_
Posted 19 January 2007 - 06:42 PM
Posted 19 January 2007 - 08:14 PM
I had to do a lot of work to the footwells with a sledge and almost cut the front inside edge of the flare away! I have seen other cars with similar combos, with hand made extended flares (cut 2 flares to make one long one). Once they cleared they never scraped once whilst driving. Parking was a bit of work though !!!
