6x9 holes in parcel shelf
_Toranaman24_
Posted 01 February 2007 - 02:21 PM
He thought that they might effect the stuctual stability of the frame or sumthing. But i do know everyone has speakers up there these days. Has anyone had any problem getting a roadworthy because of this. Also because its been unregistered for so long we need to get an engineer to look over it, would he pick us up on it?
Matt
_Flamenco_
Posted 01 February 2007 - 02:45 PM
Posted 01 February 2007 - 03:16 PM
Posted 01 February 2007 - 03:42 PM
_Flamenco_
Posted 01 February 2007 - 04:03 PM
_tweetytorana_
Posted 01 February 2007 - 04:42 PM
_1uzbt1_
Posted 01 February 2007 - 06:43 PM
I also have a vehicle that has a conversion engine in it which will also need to go over the pits,it has to big 6x9 holes in the rear shelf.So i spoke to my engineer and he said to put some patio tube under the parcel shelf and pop rivot it in.How simple,goes on the engineers certificate and legal.
_Aquarius - LC_
Posted 01 February 2007 - 07:03 PM
Out of interest,could you explain further about this patio tube.What is it?I'm trying to imagine how it would look! If it is enough to sayisfy the engineer,this may come in handy one day. Thanks in advance
_1uzbt1_
Posted 01 February 2007 - 07:54 PM
All i had to do was cut a length(ended up being about 1300mm long)and pop rivot it across the width of the car just under the parcel shelf.It just adds stregth where the metal has been cut out.Engineers may require different things though.
Posted 01 February 2007 - 08:02 PM
i think torrys are closer to 0.8mm with alot of new cars dropping down to 0.6mm to save weight.Patio tube is just thin walled rectangal steel tube,used as up right for patios.Its just 1.6mm thin steel roughly the same thickness as your vehicles sheet metal.
cant see a tube adding strength if it aint welded/bolted to anything.
as you said, an engineer will see to that.
_Aquarius - LC_
Posted 01 February 2007 - 08:11 PM
Posted 01 February 2007 - 08:48 PM
_1uzbt1_
Posted 02 February 2007 - 12:57 PM
_Flamenco_
Posted 02 February 2007 - 01:05 PM
_73LJWhiteSL_
Posted 02 February 2007 - 01:11 PM
I reckon either don't put speaker in the parcel shelf or 'pack' the speakers up enough that you don't need to cut holes.
Steve
Posted 02 February 2007 - 01:56 PM
I will give you a tip on how to get away with a cut parcel shelf, there are 2 ways to do it:
1: get a dodgy roadworthy
2: make up a parcel shepf out of MDF with no speakers in it then carpet the inside of the boot, covering over where the speaker holes are.
and dont take it back to MR muffler to get a roady
whats this about your car being off the road for so long you need an engineer to look at it? never heard of this before
_1uzbt1_
Posted 02 February 2007 - 02:30 PM
exactly just like cutting the speaker holes in it wont make much differance.Im happy,my engineer is happy with the mod as he suggested it so i aint arquing with him.Depends on if it will be driven daily or taken out on the track or drags... Then it becomes an issue! I agree with ALX76 about the patio tube, a couple of rivets wouldn't make much of a difference to the strength, it would just be like sticky tape or silicone!
_Toranaman24_
Posted 02 February 2007 - 03:22 PM
And its all ready too late to not cut the holes because they were cut when we bought it.
The speakers are already in now too so im thinking i might make up a "fake" tray to put in while we get in on the road and then just sway it over. I will be putting a sub and amp in the boot as well as the battery so at the same time it might help to put some board around and try to hide the bottom of the speakers when there in.
Thanks for all the replys too
Matt
Posted 02 February 2007 - 08:24 PM
thats bullshit, $10 says his mate is the local engineer.Makka we got told by the guy we bought it off that if it was going to become a daily drive that we need an engineer to look over???
about what I said, just cut out a piece of thin MDF to cover the whole parcelshelf and carpet the inside of the boot/parcelshelf and you will be fine
Posted 03 February 2007 - 06:10 PM
#21
Posted 03 February 2007 - 06:23 PM
