355 stroker
22 replies to this topic
#1 _1TUFSLR_
_1TUFSLR_
Posted 07 February 2007 - 11:36 AM
hey guys...
just wanted sum help from u guys ... im am planning to build a 355 stroker... but am unsure how much this would set me back... could anyone give me a rough idea on how much all the parts etc would cost to complete it and the best way to go bout it :D
cheers!!!
#2 _LH SL/R 5000_
_LH SL/R 5000_
Posted 07 February 2007 - 11:50 AM
How much horsepower do you want to make?
Carbie or fuel injection?
Street or street/strip?
#3 _1TUFSLR_
_1TUFSLR_
Posted 07 February 2007 - 12:39 PM
well i wnt it to be carbie since im a biased bastard :tease: and i wnt it to be for the street but also nice nd quick for the strip :D
#4 _LJ355_
_LJ355_
Posted 07 February 2007 - 02:27 PM
Mate i say you wont get much change out of $10.000 to do it properly if i could of i would of went a chev but my car being enginneered for the 308 was alot easier but more expensive whats it going in ?
#5 _1TUFSLR_
_1TUFSLR_
Posted 07 February 2007 - 02:42 PM
yeh i was thinking about that price but is that pritty much complete????i was thinkin bout a chev but i dont really want to go thru all that engineers crap and plus i want to keep the holden theme..... its goin into my lx slr/5000
#6 _LJ355_
_LJ355_
Posted 07 February 2007 - 04:16 PM
Yeah maybe if you shop around definatley go with the VN heads and a later model block but add on top your extractors and manifold either harrop or tourqe power 750 carb i say a barry grant thats what i got does the job nice to give you a idea i got a brand new VT block harrop crank eagle H beam rods SRP forged pistons rollmaster kit bearings rings and gaskets to suit for $5000 but thats pretty much best of the best add on top your cam lifters pushrods add another $1000 then your heads theres another $1000 atleast then someone to put it all together ??? belive it adds up and thats hopefully a 480-500 hp combo
#7 _LH SL/R 5000_
_LH SL/R 5000_
Posted 07 February 2007 - 04:22 PM
Then also a fuel and ignition system to support the engine, as well you will have to look at the driveline to see if it will handle the power you want to put through it, plus being able to stop it as well.
#8 _BCR42Y_
_BCR42Y_
Posted 07 February 2007 - 04:33 PM
To give you an idea, i just completed a 355 Stroker, and the bottom end alone cost me $8K, that is purchasing the stroker kit complete, i.e crank, pistons, bearing, rings, rods, then new timing cover, rollmaster chain, oil pump, crow cam and lifters, gaskets and the machine work invloved in it all.
I have ported VN heads with a 750 Vacsec Holley and Torque power manifold (price of these not included in $8K mentioned above) and the car goes good, i havent dynoed it yet, but would expect to get some good horsepower out of it!
Also remember that if you are going VN heads, you need to purchase the correct extractors and make the changes to the exhaust.
#9 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 07 February 2007 - 07:18 PM
We are doing a 355 at the moment for a customer, he supplied a bare block, timing cover, stripmaster manifold and bare YT -3 alloy heads. All up his is going to cost around the $11,500-12,000 mark, but will be capable of running 11.2s in a full weight HQ sedan.
#10 _LH SL/R 5000_
_LH SL/R 5000_
Posted 07 February 2007 - 07:47 PM
What sort of Hp you expecting and at what comp?
#11 _LJ355_
_LJ355_
Posted 07 February 2007 - 08:06 PM
Also to BEWARE of those cheap stroker kits from a certain sydney speed shop and anything else he sells for that matter
#12 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 07 February 2007 - 09:59 PM
The solid flat tappet cam ultimately will be what limits its horsepower, but the aim is for approx the 480hp at the flywheel, by 6500rpm. It is a combo we've done and had success with in the past, with a solid roller stick I'd hazard a guestimate and expect 530 or so from the same combination. Compression ratio is 10.8:1
#13 _LH SL/R 5000_
_LH SL/R 5000_
Posted 07 February 2007 - 10:23 PM
Combo sounds great, it is something that I want to build for mine. I have been thinking about a 370 combo, Crankshaft Rebuilders 3.625" crank, 6" rods and ACL pistons, have you built any of these combos?
#14 _HatchmanSS76_
_HatchmanSS76_
Posted 08 February 2007 - 12:13 AM
Is that on pump fuel (PULP) or Avgas?
#15 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 08 February 2007 - 12:24 AM
I'd not really like to run such a short pin height in a street engine, running a 5.7 rod would give a pin height of ~ 1.290" which would be more suitable I'd say.
Crankshaft rebuilders are definately the way to do as far as the best nodular cranks are concerned, although the wait time can be infuriating sometimes.
For those who are interested, Eagle have just released a crank for Holdens, 355ci combo with H beams, crank, forged SRPs will be under $2000 we estimate, or about $500 cheaper than similar with a Harrop crank.
Food for thought. :)
#16 _LH SL/R 5000_
_LH SL/R 5000_
Posted 08 February 2007 - 09:51 AM
How is the quality of the Eagle crank and what Hp will it support?
What type of H-beams will be available with the kit?
Obviously the kit for that price doesn't include bearings?
#17 _1TUFSLR_
_1TUFSLR_
Posted 08 February 2007 - 11:53 AM
hey guys i have found a package on ebay the adress is
http://cgi.ebay.com....1QQcmdZViewItem
just wanted to know is the products geting used here anygood??? and how bout the price???
#18 _LJ355_
_LJ355_
Posted 08 February 2007 - 01:11 PM
Thats been on there for a while but i have been stung buying a motor pre built you just dont know i really think getting one built is the way to go
#19 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 08 February 2007 - 03:03 PM
That's with 98 octane unleaded.
The cranks are rated to 500hp, Harrop rate theirs to 450, and a Crankshaft Rebuilders nitrided item is rated to 600hp.
However there are plenty of cars out there making more with both Harrops and C/R cranks. The rods and pistons are rated to 700hp, you can upgrade to ARP2000 or L19 bolts if you so choose.
#20 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 08 February 2007 - 04:16 PM
You know these engines?
#21 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 08 February 2007 - 11:36 PM
Yes, I know of 3 355's in Commodores running in the 10s with Harrop cranks.
And Brad at Crankshaft Rebuilders mentioned a few turbo'd 355's making close to 1000hp with one of their nodular cranks.
#22 _LH SL/R 5000_
_LH SL/R 5000_
Posted 09 February 2007 - 12:41 PM
Would you say that you could safely build a reliable 500HP combo with the Eagle kit? or piece all the parts together individually.
#23 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 09 February 2007 - 12:46 PM
I would say that with VN heads and the Eagle kit, you'd make 500hp on pump fuel with a roller cam. :)
