6spd in hatch
Posted 07 January 2006 - 07:03 PM
#2 _Bomber Watson_
Posted 07 January 2006 - 07:42 PM
perhaps if you heat it up with an oxy and bash the bguck out of it....cutting would be neater.
Posted 07 January 2006 - 07:55 PM
Posted 07 January 2006 - 10:49 PM
#5 _Bomber Watson_
Posted 07 January 2006 - 11:30 PM
get my point?
Posted 08 January 2006 - 01:36 AM
Posted 08 January 2006 - 06:37 AM
T5 requires the tunnel to fit as well. T56 forget about it without a fair amount of chopping and remodding.what 5speed box, I meant. Or they don't fit either?
Most US 4 speeds require cutting & massaging on LH side for linkages.
Aussie 4 speed fits fine.
Getrag 5 speed fits with a fair amount of chopping.
Trimatic fits fine.
TH350/400 is a super tight fitment without touching the tunnel.
Powerglide fits fine.
You might want to try a Richmond 5 speed?
#8 _QIKSLR_
Posted 08 January 2006 - 08:48 AM
Posted 08 January 2006 - 09:19 AM
I knew I forgot something, yep celica/supra seems to fit, there a decent box for a mild motor, cheap and plentiful.What about the celica/supra boxes? As far as i know they fit without hacking it up.
Posted 08 January 2006 - 12:03 PM
Posted 10 January 2006 - 05:04 PM
have one behind a 202. Has had the floor in gtr cut it fit [maybe because hole to oneside of tunnel]. Will a getrag fit, no cutting. I can buy a getrag for $1250 brand new. Are they any good. I want a good gearbox. I would rather pay $3000 now, then buy shit that breaks. Have a M21 and it's in good nick and would like to keep it like that.The R154 supra boxes also fit with no tunnel mods.
Posted 10 January 2006 - 05:32 PM
M@
Posted 10 January 2006 - 05:50 PM
Posted 10 January 2006 - 06:48 PM
I'm curious as my plans for our SLR include:
A fairly stout 253 ( possibly a simple motor with a centrifugal blower... or a pretty hot N/A motor),
Manual gearbox: For circuit work, nothing less than a 5 speed. I dont want to hack the tunnel though! Supra 5 speed... Will it handle the power?
Diff: Not sure. Want to steer clear of a 9", would like to go with a BW diff or something tough to handle the circuit work.
What do you guys think? I want to leave the car as standard as possible, i dont want to chop it up, i dont want to drill extra holes, i want to give it a good suspension setup, big brakes and a stock exterior and interior ( as far as possible).
Thanks!
Posted 10 January 2006 - 08:44 PM
This is what i'm doing, hope it helps.
Dave
Posted 10 January 2006 - 09:54 PM
how many thousands?Tremec 5 speed will fit without hacking the tunnel. Have to use a Mal Wood bellhousing, and send the tremec's input shaft to him to have it shortened slightly. ALso requires a non raised finger pressure plate.
Dave
Tiny, I don't know, but it will be good. I'm going to leave it standard with stripes and a good drive line, the huge brakes off my mate VZ when he trades it. Just looking stock and go like shit and don't break, a good sunday car. I want to keep building my lc 2dr 308. But If I have to rush it to finsh for reg, f@#k it. I'm not going to finsh it and put a six in it. Rather not have a car. Want a box that not break that fit's.
Posted 11 January 2006 - 11:31 PM
Bellhousing $395
Fork to suit $165
Modify input shaft and retainer $120
Clutch, depending how serious you go, $500+ (mine's about $700, cushioned ceramic)
Sounds a bit rich, but if you want it to last, better off doing it right the first time, rather than 3 times. Could be worse, could be having to blow $30K+ on your driveline like supercar guys!!
Then you'll want to run a UC cable clutch pedal, and either UC cable or commodore cable. Suggest putting a heat sleeve over the cable to prevent the inner cabel from expanding when sitting and preventing the clutch from disengaging properly.
If on a budget, can't go past a Toploader, and just give up a little in the diff gears by going taller to compensate for top end.
Edited by 355LX, 11 January 2006 - 11:34 PM.
Posted 12 January 2006 - 05:58 PM
Posted 12 January 2006 - 10:57 PM
#20 _Baronvonrort_
Posted 16 January 2006 - 01:56 PM
The Commodore cup racers used them.
Supra
Weight 1500kg
3 litre twin cam multivalve turbo with good power and torque with extra boost.
#21
Posted 16 January 2006 - 02:06 PM
THe turboed cars have a more progressive torque curve and the torque doesnt HIT as hard as when you side-step the clutch in a V8.
THats my only concern about the supra boxes! BUT for my application.. the concerns may be unwarranted!
#22 _Baronvonrort_
Posted 16 January 2006 - 02:30 PM
I have installed about 10 supra boxes into 308 Hq's Xd351's and they are all still going today after many years and the owners have had no problems.I have run mine behind a injected 265 hemi and it still feels the same after 12 years as it did when new.I would say it is 3x stronger than any gearbox holden made.
I have a friend who drifts a supra running 20 psi boost and he has blown head gaskets galore and diffs yet never had gearbox trouble.Torque increases with boost.Power is basically torque X rpm (radians per second).
The supra box is good in a street car and if you have a serious drag car it would be an auto
#23
Posted 18 January 2006 - 12:36 AM
Top Loader is a no brainer for circuit work on a budget, with a decent shifter being a priority, as the factory ones are total shite!!
Dave
#24
Posted 18 January 2006 - 09:08 AM
Anyway, that does make me feel alot better about using a supra box.. i'd REALLY like 5 gears if i could!
Dave: Thats good to know mate! The loader isnt something i thought about cause i really wanted 5 cogs, but depending on the costs involved with the oter options it could be still in consideration!
Thanks guys!
#25
Posted 19 January 2006 - 11:01 PM
Which supra box? as there are a few different models im assuming, like turbo and non turbo, and how much approx second hand and or new??Tiny
I have heard the Nissan 350Z boxes are pretty good but dont know how good or cost. They come as a six speed, any idea on the 350Z boxes guys??
