left hand steering shaft problem
#1 _UCV8_
Posted 27 February 2007 - 02:42 PM
Hope this makes sense. Any help would is very much appreciated cheers steve
#2 _LX8VD69_
Posted 27 February 2007 - 02:50 PM
adam
#3 _The Baron_
Posted 27 February 2007 - 04:12 PM
Bite the bullet and replace it with a serviced/remanufactured rack. It will sting for a little while as they are not cheap.
I think that those bits are a good indication that there is worse inside and it will cost you as much to stuff around trying to patch yours up as getting a reconditioned unit.
Save you time being off the road whilst yours is repaired.
Good that you found where the noise was coming from before it fail, not a nice thought.
#4 _UCV8_
Posted 27 February 2007 - 04:43 PM
I might put a wanted ad in section for the time being as well. cheers for all the help
#5 _LX8VD69_
Posted 27 February 2007 - 05:26 PM
#6 _UCV8_
Posted 27 February 2007 - 09:16 PM
Posted 27 February 2007 - 10:22 PM
(Boy's UC needs a steering uni and coupling)
Edited by rodomo, 27 February 2007 - 10:23 PM.
#9 _UCV8_
Posted 28 February 2007 - 12:17 PM
#10 _LX8VD69_
Posted 28 February 2007 - 12:42 PM
Posted 28 February 2007 - 04:04 PM
I don't know what I saw on the weekend.I'm sure Rares do a kit but I can't get the site up to confirm. I was looking at steering bits on the weekend on their site and I'm pretty sure I saw a kit.
The site is back up and, no they don't do a kit.
I also PMed Les from Rares (when I couldn't get the site up) and he confirmed no.
Cheers Les.
#12 _UCV8_
Posted 10 March 2007 - 01:47 PM
I sourced a new one from my old local auto shop, for everyones info the commodre uses the same bush in the steering as torries.
Bought two in the vision of replacing both sides.
Got home very excited after a 1.5 hr drive. Pulled the wheels off, calipers off etc.
Followed the manual for pulling steering off car. For anyones info who has or is planning to put an 8 in their UC while you have the engine out check your steering. Not sure if LH/X is the same but you need to seperate the steering pinion from the column.
To do this you need to remove the cover that is over the steering dampner. Impossible to do with extractors. hence needing to remove engine to remove steering.
Scratch bald head now.
Move back to steering arm to discover ball pivot is held in by locknut with pin bewteen it and ball housing. Drilled pin out but unfortunately destroyed locknut in process. I now have steering(tie rod arm) off and bush fits in perfectly. I have not put it back together as I need fluid, new boots, locknut etc.
Drivers side pin is impossible to drill out so will need to either leave it or find another way.
Anyway just thought I would let the UC owners know of problems with an 8 installed.
steve
#13 _v8slrtorana_
Posted 24 April 2007 - 09:22 PM
I was going to ask if the UC's have this bush. Thought id search before asking.
I just put a UC rack in LH and i felt the movement when i grabed the tie rod end after installing the rack.
I remember having to replace the bush on my brothers old VC.
So, how did you go?
Did you end up replacing both? Or is their only one bush?
Oh, im doing a engine change at the moment, so im finding it easy
#14 _UCV8_
Posted 10 May 2007 - 04:17 PM
Steering is the best it has ever been on the car. Feels really tight and responsive. This makes me wonder how long the bush was breaking up for.
All up took less than an hr to put back together. Hardest bit was to find lock nut. Tip be very careful drilling pin out of locknut if you decide to do bush.
