Rocker Posts..304/308
Posted 13 March 2007 - 10:21 PM
Posted 13 March 2007 - 10:24 PM
Posted 13 March 2007 - 10:26 PM
Edited by rorym, 13 March 2007 - 10:27 PM.
Posted 13 March 2007 - 10:32 PM
Posted 13 March 2007 - 11:40 PM
Posted 14 March 2007 - 12:35 AM
5/16 sounds right.
be carefull tightening them as takingg the posts out that far leaves them prone to cracking thru over tightening.
Posted 14 March 2007 - 07:24 AM
_82911_
Posted 14 March 2007 - 08:50 AM
WTF are those studs?????
The stress riser that the step in the stud would cause would be unbelievable!!!
I wouldn't put them in my mower let alone an engine that you are going to put a big set of valve springs on and then use in an endurance application.
7/16 studs and guides.. It is 1 less thing to worry about.
My personal favorite is the Yella Terra Platinum series of shaft mounts. rigid as all get out, and heaps quicker to adjust than post style rockers.
The downside.. they are not cheap.
The standard thread in the heads for standard rocker posts are 3/8" UNC 24TPI if that is what you were asking?
Cheers Greg..
Edited by 82911, 14 March 2007 - 08:53 AM.
Posted 14 March 2007 - 08:53 AM
_82911_
Posted 14 March 2007 - 08:56 AM
Where did you get them from?
Cheers Greg..
Posted 14 March 2007 - 09:07 AM
_82911_
Posted 14 March 2007 - 09:11 AM
It looks like their engineering standards.
Put them in the bottom of the toolbox, you'l use them one day.
Cheers Greg..
Posted 14 March 2007 - 01:52 PM
(I must read topic heading properly before I post)
(I also suffer from premature ejaculation)
_bones_
Posted 16 March 2007 - 06:59 AM
I wouldn't use those studs you have unless you are the type of guy that would be happy securing a HQ onto a car trailer with a few small plastic zip ties.
Bones
Posted 16 March 2007 - 07:31 AM
_brett_32i_
Posted 17 March 2007 - 10:14 PM
a mate has an old carby fed red 308 which had l34?? heads on it with roller rockers.
he has now dropped in an injected 304 and went to put the roller rockers on. they were totally wrong. pushing the valve way open.
question is... is it as easy as pushrods, or are the pedestals at different heights?
Posted 17 March 2007 - 11:00 PM
If the valves are being held open then this is where pedestal height comes into effect.
Are you comparing the standard lift from the standard rockers as to the rollers which may have a higher lift ratio?
Another, but unrelated to your question piont is that yella terra shaft mount have a slight different arrangement from pre efi to the efi heads. i.e. the shaft sets (inlet/exhaust) come in two lots for the earlier heads with 4x having a different offset to the other 4x set. So looking at a head you would fit two the same to the first two inlet/exhaust pedestals and the opposite two sets to the last two pedestals.
Later heads just use the one type. Using the old style on VN on heads may mean some of your rollers may not be true on center of the valve tip.
As stated this only applies to shaft mount race style YT rollers.
What is your mate using?
Edited by ALX76, 17 March 2007 - 11:01 PM.
_brett_32i_
Posted 19 March 2007 - 01:55 PM
yes they are a higher lift, but nothing stupid. so i reckon them being held open is therefore due to pedestal height?
i suggested getting some 5/16 washers and throwing them under to see what affect it has.
_bodallafella_
Posted 19 March 2007 - 05:51 PM
Your best bet is to take the pushrods out to set the pedestal height and then use an adjustable pushrod to work out what length you need.
For more info see here:
http://www.mid-lift....nstalled-G1.htm
Posted 22 March 2007 - 02:50 AM
