LC thermos
13 replies to this topic
#1 _uglybob_
_uglybob_
Posted 11 January 2006 - 08:21 PM
gday im wanting to get a thermo fan for my lc as the norm isnt making the cut i hav a three core radiator but i think the problem is that it just cant draw enough air! so wot sort of thermos are you people runnign in your lc's??
#2 gtrboyy
gtrboyy
  • 3,219 posts
Posted 11 January 2006 - 08:44 PM
When I had a heavily worked six I had a vk radiator with a 16in baco fan in front of the radiator but it was angled slightly to fit the fan in.The wouldnt even overheat on the hottest of days,
#3 _Bomber Watson_
Posted 11 January 2006 - 09:15 PM
i have a 12 inch on the front up the top left corner and a 9 inch on the back down the bottom right corner...tucked just inside the lower rad hose. works a treat.
#4 _uglybob_
_uglybob_
Posted 11 January 2006 - 09:37 PM
ok then two different sized fans from what? have u got a photo of that set up? the single 16 in. baco sounds good but how do u mean angled it ?
thanks for the feed back fellas
#5 _Bomber Watson_
Posted 11 January 2006 - 09:42 PM
the 12 only just fits with a tiny bit of spare room on the radiator core...a 16 would be way bigger so would have to be made to fit. woudl work well though.
#6 _uglybob_
_uglybob_
Posted 11 January 2006 - 09:48 PM
ok then no worries would just the 12 inch by itself be no good? is that why u added the extra 9 inch one??
#7 rodomo
  • 18,042 posts
Posted 11 January 2006 - 10:17 PM
What are you blokes using to turn your fans on?
RACV MAN
#8 _UCV80_
_UCV80_
Posted 11 January 2006 - 10:30 PM
what is better?
bout to get some for my torrie.... commo style radiator so its quite high probly 16" high of the fins
1x 16" thermos
or
2x 10" thermos
nathan
#9 J-Rod
J-Rod
  • 189 posts
Posted 11 January 2006 - 11:05 PM
IIRC a 16" davies craig fan flows almost 50% more than a pair of their 10" fans.
#10 gtrboyy
gtrboyy
  • 3,219 posts
Posted 12 January 2006 - 05:24 PM
My vk radiator sat a little closer to the eng at the bottom,the top was angled slightly forward so that the fan fitted,I used just a switch to turn it on/off but those temp switches + a override switch from jaycar etc would be much better.I also had to use an 80amp alternator as it was slowly draining the battery running everything on a hot night stuck in traffic.
#11 _@milco@_
_@milco@_
Posted 12 January 2006 - 09:52 PM
i got twin 10 inch fans on my lj, they fit perfectly on the front of the radiator in a lj/lc
michael
#12 _uglybob_
_uglybob_
Posted 13 January 2006 - 04:42 PM
thats wot i was after milco wot brand are they. if i hav a brand they should be easier to track down.
thankx for the feed back from everyone much appreciated!
ben
#13 _Oldn64_
_Oldn64_
Posted 17 January 2006 - 01:51 PM
I ran two KC laser thermos when I had teh EH. Never ran hot at all. Ran the temp switch (cannot remember which one now) to turn it on. One was on the inside and the other on the outside. It is known that the laser fans turn a hell of a lot faster than most. I think they are 8-10inch in diameter and move a hell of alot of air. If doing thermos again I would not think about anything else. Besides the wreckers want approx $25 for them.
PS: Magna aircon fans are 10" Davis ones. Look at your local wreckers for them.. :)
#14 _@milco@_
_@milco@_
Posted 17 January 2006 - 10:36 PM
ben
got them from ebay i will link you wait, came with free thermostat as well
http://cgi.ebay.com....1QQcmdZViewItem
